Edge Software Catalog
478 Discussions
ECI kernel panic when enable ftrace utility
bmh8x
I would like to enable ftrace utility for my Intel ECI 3.0.1 (Distribution: Debian11 (Bullseye) , Linux kernel type: Real-time PREEMPT_RT,  Linux kernel version: 5.10.140-rt73-intel-ese-standard-lts-rt+), but when I execute these following two commands, a kernel panic occurred.
  # echo 'p:ndprobe d_splice_alias inode=%di' > /sys/kernel/debug/tracing/kprobe_events
  # echo '1' > /sys/kernel/debug/tracing/events/kprobes/ndprobe/enable
On the other hand, kernel panic do not happen with Debian 11(kernel version: 5.10.0-18-amd64).
So I would like to ask why does a kernel panic occur in ECI? And is there a solution?
Best regards
Bui
Iffa_Intel
could you check whether your kernel configuration enables the ftrace, as in step 2?
You may refer to this documentation.
Cordially,
Iffa
bmh8x
Hello Iffa,
Thank you for your reply!
I have checked my kernel configuration. All kernel parameters required for ftrace in step 2 are enabled.
Please find the attached file for your reference.
Best regards
Bui
Iffa_Intel
could you:
  1. try the same steps on the latest ECI release (3.2)?
  2. share the hardware specs for this system.
Cordially,
Iffa
bmh8x
Hello Iffa,
Thank you for your advise!
       >1.try the same steps on the latest ECI release (3.2)?
→I will try with  ECI 3.2 and I will let you know the result later.
       >2.share the hardware specs for this system.
→My hardware specs are as follows:
       ・CPU: Intel Atom(R) x6414RE Processor @ 1.50GHz
       ・MEM: 8GB
Please feel free to ask me if you need more information.
Best regards
Bui
Iffa_Intel
do inform us soon whether the ECI 3.2 release works.
Cordially,
Iffa
bmh8x
Hello Iffa,
I'm so sorry for the late reply.
I am still preparing for my ECI 3.2 machine.
I will let you know the result next week.
Best regards
Bui
Iffa_Intel
Noted and thanks.
Cordially,
Iffa
Iffa_Intel
if you don't have any other inquiries, we'll proceed to closing this thread.
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
