Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
ECI release-eci_3.3 Build error
Xander3
When I first attempted to build, it successfully completed. However, after I reran the ./setup.sh script and chose to start building with core-bullseye, an error occurred. I am using ECI version 3.3, with a system version of Debian 11 and a kernel version of 5.10.0-33-amd64. Could you please give me some hints on how to resolve this issue?
Wan_Intel
Hi Xander,
Thanks for the information.
If you are behind a proxy, make sure that you set the following environment variables: HTTP_PROXY, HTTPS_PROXY, and NO_PROXY. On the other hand, could you please try from a network that does not require proxies?
Wan
Peh_Intel
Hi Xander3,
This is a known limitation with ECI. When building ECI, the build process may fail due to do_fetch errors. These errors occur when the build engine is unable to reach external dependencies via the network. Most often, these errors occur due to network instability, broken mirrors, or proxy server instability.
I was able to reproduce the issue and had tried several attempts but still having the do_fetch errors. As such, I need to check with the development team regarding this matter.
In a meanwhile, you can try with another way installing ECI, which is to use packages provided with the ECI release.
Peh
Xander3
Thank you for your reply.I have tried the Install Packages method before, but the results tested using start-cyclic.py were poor. Is it possible to obtain the best results by using the Build ECI from Source and Install method to install ECI?
Wan_Intel
Hi Xander3,
Do you use a proxy when you install the ECI? On the other hand, do you install the ECI on a fresh Operating system?
Wan
Xander3
I have already used a proxy and installed ECI on a fresh operating system.
Wan_Intel
Hi Xander,
Wan
Wan_Intel
Hi Xander,
Thanks for the question.
This case will no longer be monitored since we have provided suggestion.
If you need additional information from Intel, please submit a new ticket.
Wan
