Edge Software Catalog
489 Discussions
EI-AMR: Follow Me Demo Not Installing Correctly
ChrisMatthieu
Hello
I seem to be having trouble installing:
sudo apt install ros-humble-followme-turtlebot3-gazebo
Could you let me know if you see any issues or have any advice?
Note: I am able to run the demo in 3 terminals but it seems to be having trouble identifying me...
Thanks in advance.
Chris
ChrisMatthieu
I resolved the issue by commenting out the Aaeon robot controller (as it does not exist on my custom built robot) and reduced the complexity from 2 cameras to 1 camera in the bash script.
Iffa_Intel
You are referring to an older version of Robotic SDK tutorial.
It is recommended to follow this latest tutorial (version 2.1) instead, which utilizes ROS 2 components.
Cordially,
Iffa
ChrisMatthieu
I reinstalled everything (V2.1).
When I run the first follow me tutorial (without gesture recognition (https://amrdocs.intel.com/docs/2.1/dev_guide/tutorials_amr/navigation/follow_me/Tutorials/followme-on-aaeon.html#run-demo), everything seems to run but ends abuptly with a ros2run: Segmentation fault.  See attached.
I seem to have better results with the follow me with gesture recognition tutorial (https://amrdocs.intel.com/docs/2.1/dev_guide/tutorials_amr/navigation/follow_me/Tutorials/followme-with-gesture-on-aaeon.html#run-demo-with-realsense-camera). No errors but it never seems to recognize the thumbs-up or thumbs down gesture; therefore /cmd_vel is always reporting 0 on all twist properties.
Three questions:
1. What could be causing the segmentation fault in the first demo?
2. What could be causing the gesture recognitions to fail?
3. Is there a way to run the second demo with without the gestures?
Chris
ChrisMatthieu
Looking through the above logs, I see these messages related to gesture:
Custom gesture classifier is not defined.
https://gist.github.com/chrismatthieu/b9b264c3b619c1bef93113a8218c0097
Iffa_Intel
From the image that you shared, it seems that the issue originates from your camera (Realsense) setup.
We'll further investigate this and get back to you with possible workaround.
Cordially,
Iffa
ChrisMatthieu
Iffa_Intel
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Cordially,
Iffa
