Edge Software Catalog
475 Discussions
EII3.0 network setting issue with tutorials program (Defect Detection Demo)
AmandaLee
Dear Sir,
Target system: EII 3.0, Intel(R) Core(TM) i7-1185G7E CPU, Ubuntu 20.04.
We run "defect detection demo" with local address "10.21.xx.xx", the visualizer displays well.
But when we change the local address to 192.168.xx.xx that demo will fail (Using mobile wifi hotspot). How can i debug it?
    docker_network.txt: "$docker network inspect edgeinsightsoftware_eii"
    ia_web_visualizer_log.txt: "$docker logs ia_web_visualizer"
"$ping 172.20.0.4" ia_web_visualizer ip address is available.
wifi setting
Webpage "ia_web_visualizer" fail.
Amanda
JesusE_Intel
Hi Amanda,
Looking further into it, you don't need to rebuilt when changing the network/host ip. Simply update the HOST_IP and ETCD_IP in .env located in the build directory. Then simply run the following commands:
./source.sh
./eii_start.sh
Ref: https://open-edge-insights.github.io/IEdgeInsights/DeploymentToolFrontend/README.html#bring-up-the-containers
Regarding, the mbedtls package, let me report that to the development team.
Jesus
JesusE_Intel
Hi Amanda,
The HOST_IP and ETCD_HOST are automatically populated with the current system's IP when builder.py is executed if the variables are blank. If you need to use a different network/IP address, please set the correct HOST_IP and ETCD_HOST in .env file and re-run the builder.py to generate the certificates and configure the system using the new system's IP address.
cd <install_directory>/edge_insights_industrial/Edge_Insights_for_Industrial_3.0/IEdgeInsights/build
vi .env
python3 builder.py
docker-compose -f docker-compose-build.yml
./eii_start.sh
Jesus
AmandaLee
Hi Jesus,
Thanks for your help.
It is workable after modify HOST_IP and ETCD_HOST value.
Two other questions:
1. Where can i find the document of this?
2. Is there any other way to change HOST/ETCD ip at runtime? (Rebuild all images takes too long....)
Thanks and Regards,
Amanda
JesusE_Intel
Hi Amanda,
./source.sh
./eii_start.sh
Jesus
AmandaLee
Hi Jesus,
Many thanks for your assistance.
Amanda
JesusE_Intel
Happy to help! If you need any additional information, please submit a new question as this thread will no longer be monitored.
