Edge Software Catalog
471 Discussions
ESDQ Error with Video Analytics v2022.1 - Object Detection GPU pipeline
PH_ROC
Hi Intel,
I had test ESDQ Video Analytic v2022.1 with an error in the test result. Test report as attached file.
I had tried to solve the issue as the follow link:
https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-edge-video-analytics.html
But still get same error result, Is there any method could fix the issue?
Please help to clarify, thanks you.
Sincerely.
JesusE_Intel
Hi PH_ROC,
Thank you for sharing the docker log output! I noticed the following error:
{"levelname": "ERROR", "asctime": "2023-03-15 08:19:15,731", "message": "RTSP Stream at /vasserving already exists, use different path", "module": "gstreamer_rtsp_server"}
{"levelname": "ERROR", "asctime": "2023-03-15 08:19:15,739", "message": "Error on Pipeline 132e4ff8c30a11edacdb0242ac120003: RTSP Stream at /vasserving already exists, use different path", "module": "gstreamer_pipeline"}
{"levelname": "INFO", "asctime": "2023-03-15 08:30:01,492", "message": "Pipeline d4602dbec30911edacdb0242ac120003 Ended", "module": "gstreamer_pipeline"}
I'm not entirely sure this is related to the EVAM test failing with GPU. Is it possible to test on another system or a fresh OS install?
Jesus
JesusE_Intel
Hi PH_ROC,
Thanks for reaching out, I was not able to root cause the error from the log files. Could you please run esdq one more and copy/paste the entire output of the terminal?
From my side, I tested on an 11th gen system and the GPU pipeline failed due to a connection refused error when downloading the model. Running esdq a second time had a successfully GPU pipeline. Do you see the same error every time you run esdq?
Also, I did see a warning about the system not meeting the minimum requirements. Please ensure the system requirements are met.
https://www.intel.com/content/www/us/en/developer/articles/technical/edge-software-device-qualification-edge-video-analytics.html#inpage-nav-1
Jesus
PH_ROC
Hi JesusE_Intel,
Thank you for reply,
I had test again with 8GB RAM, but still have same error.
For entire terminal output and report, please refer to the new upload attached files.
Sincerely.
JesusE_Intel
Hi PH_ROC,
I'm not seeing any error message in the logs or terminal output. Would you mind sharing the output of the following commands?
$ groups
$ docker ps -a
$ docker logs edge_video_analytics_microservice
Jesus
PH_ROC
Hi JesusE_Intel,
FYI, please refer to the attached file.
Sincerely.
JesusE_Intel
Hi PH_ROC,
Jesus
JesusE_Intel
