Edge Software Catalog
485 Discussions
Fail to setup message bus for eiiv3.0
Tconnell
Why are you recompiling the message bus? What is the use case that you have that is not supported in our release build?
* setting up message bus for running ZeroMQ example usage
 OS version:
* Ubuntu 20.04.4 LTS
Kernel version:
* 5.13.0-44-generic
CMake version:
cmake version 3.15.0
Has you completed all the ‘Dependency Installation’ steps? Any error or warning?
Yes, I am following the step stated in this link: https://open-edge-insights.github.io/3.0/pages/msgbus.html
There is no error/warming until the compilation step.
On the compilation, are you using any of the flags(-DWITH_PYTHON, -DWITH_GO, with Debug, etc)?
The first attempt, I without using any flags. After I failed I added -DWITH_PYTHON
Can you also attached along the error log?
Attached
Sahira_Intel
I see the error: cannot find -lpthreads
That library could be missing. can you search for the pthreads library on your system: apt-cache search pthreads
Sincerely,
Sahira
