Edge Software Catalog
475 Discussions
Failed to execute script docker-compose
HuynhVanThuan
I am having problems with provison, build and run docker-compose when i am trying to inference EII. Can you help me with this problem?
Regard,
Huynh
JesusE_Intel
Hi Huynh,
I believe your docker needs to have elevated permissions, please try to use sudo or add your user to the docker group and set the permissions accordingly.
Also, Edge Insights for Industrials v2.6.3 is only supported on Ubuntu 18.04. If you want to continue using Ubuntu 20.04, you can use Edge Insights for Industrial v3.0. See system requirements for additional information.
Jesus
JesusE_Intel
Hi Huynh,
Jesus
JesusE_Intel
