Edge Software Catalog
477 Discussions
Failed to install Automated_License_Plate_Recognition. tuple index out of range on Win11 WSL2 Ubuntu
jacky0327
Hi Intel,
I am currently experimenting with EII ALPR on Win11 WSL2 Ubuntu 20.04,
https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/automated-license-plate-recognition.html
I have successfully set up this case on my computer with the operating system Ubuntu 20.04.
I'm experimenting with installing WSL2 Ubuntu 20.04 on Windows 11, and installing EII ALPR, but the following error occurred,
ERROR: You need to run with GUI.
Clean up function
As shown below,
I have referenced the previor cases:
https://community.intel.com/t5/Intel-Edge-Software-Hub/ERROR-Failed-to-install-Automated-License-Plate-Recognition/m-p/1405644
https://community.intel.com/t5/Intel-Edge-Software-Hub/Docker-configuration-manager-agent-did-not-finish-provisioning/m-p/1406639#M1359
But it still doesn't solve this problem, no matter how many times I reinstall docker, when I issue the following command:
sudo ./edgesoftware install
After installing an error, I found that when I issued the following command:
sudo apt remove docker docker-engine docker.io containerd
docker has been deleted, as shown below,
Please help me to solve this bugs, I'm very interested in EII, thanks Intel.
BTW, I once succeeded once after do many debugs (unknown reason), since then, no matter how I rebuild, the above errors will appear.
JesusE_Intel
Hi Jacky,
I was able to install Automatic License Plate Recognition on Ubuntu 20.04.5 LTS running on WSL2 (version 1.0.3 using the steps below. Please note these are not official steps and have not been validated to work. We recommend using Ubuntu 20.04 running natively on your system. As I mentioned, I have passed your request to support this software package on WSL2 to the development team. Hope this helps!
Enable systemd by creating the following file and rebooting using wsl --shutdown on a separate cmd.
sudo vi /etc/wsl.conf
[boot]
systemd=true
Install updates and pre-requisites and rebooting using wsl --shutdown on a separate cmd.
sudo apt update
sudo apt upgrade
sudo apt install unzip python3-pip x11-apps x11-xserver-utils ca-certificates curl gnupg lsb-release
python3 -m pip install --upgrade pip
Install Docker and set user permisions.
sudo mkdir -p /etc/apt/keyrings
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
echo \
 "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.gpg] https://download.docker.com/linux/ubuntu \
 $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io docker-compose-plugin
sudo groupadd docker
sudo usermod -aG docker $USER
newgrp docker
Install Reference Implementation
unzip automated_license_plate_recognition.zip
cd automated_license_plate_recognition/
chmod 755 edgesoftware
Jesus
JesusE_Intel
Hi jacky0327,
I have seen this issue when setting up this reference implementation on Ubuntu 20.04 without GUI. I had no issues installing the software package when using a fresh Ubuntu 20.04 system with GUI. That being said, we have not validated this software package on Ubuntu 20 running on Windows Subsystem for Linux.
I recommend using a system running Ubuntu 20.04 natively.
Jesus
jacky0327
Hi JesusE_Intel,
We have a requirement: use subsystem Ubuntu 20.04 on Windows.
After we tried for a long time, we succeeded once: using the subsystem Ubuntu 20.04 to install EII ALPR on windows, as mentioned in this case.
But when I then installed public-transit-analytics, after encountering some bugs, I used the following command to delete the docker images.
sudo docker system prune --volumes
sudo docker stop $(sudo docker ps -aq)
sudo docker rm $(sudo docker ps -aq)
sudo docker rmi -f $(sudo docker images -aq)
https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/public-transit-analytics.html
When I deleted all docker images, I reinstalled EII ALPR on a clean docker, and the installation was no longer successful. The problem mentioned in this case has been appearing, I hope this problem can be reproduced and supported.
We have succeeded on Ubuntu 20.04 with gui, so are experimenting how to do it on the windows subsystem (WSL with Ubuntu 20.04).
Thanks for Intel reply.
Jacky
JesusE_Intel
Hi Jacky,
Switching between reference implementations can be tricky and may need to remove the docker images/container prior to installing another RI.
I did a quick test on a fresh Ubuntu 20.04 on Windows 11 WSL 2 and ran into the following error message.
--------Succesfuly installed prerequisites--------
All dependencies met
Unsupported OS. Please check your OS version
The software package needs to run on a system running Ubuntu 20.04 natively. I have passed your feedback to the development team to consider supporting WSL2 in the future. Please let me know if you have any further questions.
Jesus
jacky0327
Hi JesusE_Intel,
It is mentioned later in this RI that it can be combined with another RI,
I have success in Ubuntu 20.04 with GUI as shown below,
But I only succeeded once when I run this RI on Windows 11 WSL2,
I also encountered this warning,
--------Succesfully installed prerequisites--------
Install WSL2 at this time will install Ubuntu 22.04 by default. It is very troublesome that you need to refer to some special instructions and steps to completely remove Ubuntu 22.04 in Windows 11 and reinstall Ubuntu 20.04, because OpenVINO currently only supports 20.04.
When Ubuntu 20.04 is correctly installed on WSL2 and run this RI, the bugs raised in this case will be encountered.
Thank you for helping to passed my feedback to the development team.
Jacky
JesusE_Intel
Hi Jacky,
[boot]
systemd=true
sudo apt update
sudo apt upgrade
echo \
sudo apt-get update
newgrp docker
Jesus
JesusE_Intel
