Edge Software Catalog
475 討論
Industrial surface defect detection: Failed to install Model optimisation
Nitish_
新手
2,316 檢視
Hello everyone,
I  am trying the run the Industrial surface defect reference implementation on my Ubuntu 18.04. Unfortunately, model optimizer is not installing and giving me error. Please check the screenshot.
I adopted the same process as given here:  https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/industrial-surface-defect-detection.html
Will appreciate your suggestion/recommendation/insights.
0 積分
1 解決方案
JesusE_Intel
主席
2,261 檢視
Hi Nitish_,
The issue seems to be related to OpenCV (see below), are you running Ubuntu 18.04 in a virtual environment? If so, please try to install it on a system running Ubuntu 18.04 natively.
* FATAL ERROR:                          *
* This OpenCV build doesn't support current CPU/HW configuration *
* Use OPENCV_DUMP_CONFIG=1 environment variable for details   *
Required baseline features:
  ID= 2 (SSE) - OK
  ID= 3 (SSE2) - OK
  ID= 4 (SSE3) - OK
  ID= 5 (SSSE3) - OK
  ID= 6 (SSE4.1) - OK
  ID= 8 (POPCNT) - NOT AVAILABLE
  ID= 7 (SSE4.2) - OK
terminate called after throwing an instance of 'cv::Exception'
 what(): OpenCV(4.5.1-openvino) ../opencv/modules/core/src/system.cpp:626: error: (-215:Assertion failed) Missing support for required CPU baseline features. Check OpenCV build configuration and required CPU/HW setup. in function 'initialize'
Ref. Can't solve OpenCV build error due to no POPCNT support on CPU · Issue #18932 · opencv/opencv (github.com)
Jesus
在原始文章中檢視解決方案
7 回應
JesusE_Intel
主席
2,298 檢視
Hi Nitish_,
Thank you for reporting, I was able to reproduce the issue from my side. Looking at my logs, OpenVINO Model Optimizer failed to install after onnx was not able to install. As a workaround, could you try to manually install onnx and run the ./edgesoftware install again?
pip3 install onnx==1.7.0
Jesus
Nitish_
新手
2,293 檢視
Hi Jesus,
Despite installling onnx , the same problem persists. Could you pls let me know the command to  view logs that may help to resolve this issue? Model optimiser is not going beyond 66%.
Nitish
JesusE_Intel
主席
2,288 檢視
Hi Nitish,
Could you share your logs with me? Logs can be found in the /var/log/esb-cli/<reference_implenetation> directory.
Jesus
Nitish_
新手
2,282 檢視
Hi Jesus,
Please find the install.log file.
Nitish
JesusE_Intel
主席
2,262 檢視
Hi Nitish_,
* FATAL ERROR:                          *
  ID= 2 (SSE) - OK
  ID= 3 (SSE2) - OK
  ID= 4 (SSE3) - OK
  ID= 5 (SSSE3) - OK
  ID= 6 (SSE4.1) - OK
  ID= 7 (SSE4.2) - OK
Jesus
Nitish_
新手
2,254 檢視
Hi Jesus,
Thank you :). The issue got resolved by following reference details.
Ref: https://www.virtualbox.org/ticket/20005
Nitish
JesusE_Intel
主席
2,248 檢視
Hi Nitish,
You're welcome! If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jesus
回覆
