Edge Software Catalog
475 Discussions
Real-time Sensor Fusion for Loss Detection Reference Implementation: ""configuration provider is no"
Markus_B_Intel
After installing "Real-time Sensor Fusion for Loss Detection Reference Implementation" by following "https://software.intel.com/content/www/us/en/develop/articles/real-time-sensor-fusion-for-loss-detection.html".
Installation went fine (except "GO", which wasn't found, wasn't installed, so needed to be installed separately first), the application(s) could be built, the application(s) started.
However, in step "Step 4: Simulate Data", the logs via "docker logs -f event-reconciler" shows:
app=EventReconciler source=config.go:167 msg="Using Configuration provider (consul) from: http://edgex-core-consul:8500 with base path of edgex/appservices/1.0/EventReconciler"
app=EventReconciler source=config.go:134 msg="configuration provider is not available"
(repeated 30 seconds)
app=EventReconciler source=logger.go:74 msg="logTarget cannot be blank, using stdout only"
app=EventReconciler source=registry.go:79 msg="Using Registry (consul) from http://edgex-core-consul:8500"
app=EventReconciler source=bootstrap.go:43 msg="unable to register with Registry in allotted time"
Does anyone have an idea what went wrong?
(I'm in corporate network behind a network-proxy) (having proxies and DNS configured for Docker)
Nadia_J_Intel
Hi Markus,
Can you follow these steps and see if you still observe the same issue ?
Nadia_J_Intel
May I know if you are using this on Ubuntu 18.04 or Ubuntu 20.04 ?
Markus_B_Intel
I'm using Ubuntu 18.04.5 LTS.
I had Docker and Docker-Compose installed before, only GO was missing.
Everything else (build the applications, build the containers, run the containers) look good from console output.
But the logs "docker logs -f event-reconciler" show a problem with the event-reconciler.
Maybe a network-proxy issue, a firewall issue?
Is there anything to check?
I haven't continued with the description like installing "Postman".
Nadia_J_Intel
Hi Markus,
Markus_B_Intel
Thank you very much for your response - I can confirm, by renaming/deleting the existing Docker-config file (and letting Docker create a new one), the log-messages show the service being initialized successfully!
