Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
493 Discussions
Run work-zone-analytics reference kit error in Ubuntu
Song8633
When I run the reference kit follow below link , there are two issues, how to solve? thanks
Reference fit: https://www.intel.com/content/www/us/en/developer/articles/reference-implementation/work-zone-analytics.html
issue 1: Can not download Docker_commuity_Edition_CE
Issue2 2: Fail to install esb_common
Vipin_S_Intel
Hi Sophie, we would like to inform you that we are routing your query to the dedicated team for further assistance.
Iffa_Intel
Before proceeding further, could you clarify:
  1. Are you running Ubuntu* 20.04 LTS OS?
  2. Does your hardware within the range of 6th to 10th Generation Intel® Core™ processors with Intel® Iris® Plus graphics or Intel® HD Graphics?
  3. Are you using proxy?
Cordially,
Iffa
Song8633
Hi
OS: Ubuntu 20.04 LTS
Hardware: 8th CPU i5 8500 with Intel® UHD Graphics 630
Proxy:No
Others:I can download other packages successfully, but Docker_community_Edition_CE Failed as the picture in first question
Iffa_Intel
I can the same issue from my side.
We'll further investigate this.
Cordially,
Iffa
Song8633
Iffa_Intel
From our side, we did not notice 404 errors.
We did encounter a docker permission denied which was resolved by doing the docker post install linux steps mentioned here: Linux post-installation steps for Docker Engine | Docker Docs
There is another error encountered which was resolved by making the change below and running the ./edgesoftware install command.
/opt/intel/eif/EII-UseCaseManager/edge_insights_for_fleet/scripts/download_js.sh
Line #: 12
From: BASE_URL="https://cdnjs.cloudflare.com/ajax/libs/"
To: BASE_URL="https://cdnjs.cloudflare.com/ajax/libs"
Have you tried to re-install and see whether the same issue persists?
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
