Edge Software Catalog
471 Discussions
Training Stopped due to exceeding memory limit for $group
Lin__Joey
Innovator
Dears,
This is a native version of DLS on a fresh installed Ubuntu 18.04. I had succeed with a
200 skin tumor object detection training using CPU. This time, however, it fails on a 600+ fire & smoke object detect training images with an error, showing "exceeded memory limit...". Please see attached screen shot for details.  The model selected and setting are same for both projects.
Joey
JinPei_N_Intel
Hi Joey,
May i know your hardware spec?
Jin Pei
Lin__Joey
Innovator
Dear JinPei
Intel® Core™ i5-7500TE (2.3 GHz, quad-core, TDP=35W)
●Chipset: Intel® Q170
●System Memory:
2 x 260-pin DDR4 SO-DIMM, pre-installed one 8GB (system max: 32GB)
●Power:
Input - DC Jack: 9 V~36 V DC, Terminal Block: 9 V~36 V DC
Consumption: 19 V@3.68 A (Intel® Core™ i7-6700TE with 8 GB memory)
Internal Connector: 5V@3A or 12V@3A
●Reliability:
Operating Shock - Half-sine wave shock 5G; 11ms; 100 shocks per axis
Operating Vibration - MIL-STD-810G 514.6 C-1 (with SSD)
Safety/EMC - CE/FCC
●IPMI: 1 x iRIS-2400 (optional)
JinPei_N_Intel
Hi Joey,
Do you mind capture the memory usage while running the training?
It seems like is hardware limitation, but i would like to further debug before have a conclusion on it.
