Edge Software Catalog
473 Discussions
can you provide me the requirements-gpu.txt using in the installation of tls
fa2233
see subject
fa2233
i only find the requirements.txt for CPU setting .  is this file the same as requirements-gpu.txt
Jia-Shing_W_Intel
No, those are different files. requirements-gpu.txt got removed in the 2.2.1 release, and I am trying to find out why for you. Thank you for your patience.
Jia-Shing_W_Intel
According to the TLS engineer, "The requirement-gpu.txt is remove in 2.2.1 is because the docker setup only support TLS run In CPU." Sorry about the inconvenience...
JinPei_N_Intel
Currently, TLS only support training in CPU.  Sorry that we could not provide the requirements-gpu.txt, it will causes the setup not compatible. Sorry for the inconvenience.
