Edge Software Catalog
The Edge Software Catalog community is read-only. For support, please visit the Open Edge Platform (https://github.com/open-edge-platform) GitHub organization and post your question in the relevant repository’s Issues section.
492 Discussions
why there hasn't one single 64-bit assembler sdk by intel
fairyfoxhujiujiu
emm ..... for getting 64-bit assembler and 64-bit assembler language article for personal fun , has been searching around again and again ............ finally I find a fact that I can get nothing about it ...........
so , as intel can create such more softwares and hardware equipments that can be in personal use , why just 64-bit assembler program resources can't be found ??
or if not on intel , where else can I find other 64-bit assembler sdk ??
JesusE_Intel
Hi fairyfoxhujiujiu,
I recommend posting your question on the compiler forums for an accurate answer. There is a similar discussion that may be helpful to you. Solved: Assembly Language Programming - Intel Communities
Jesus
JesusE_Intel
Jesus
JesusE_Intel
