Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
82599 Ethernet programming utility
cathyz64
Hi. We are integrating a 82599 chipset onto a board that we are building. We want to be able to set one interface to use 10GBASE-KR and the other interface to use 1000BASE-KX. This is a non-standard interface. From what we can tell looking at documentation, we will need to program the EEPROM onboard in order to achieve this configuration. Can you point me in the right direction of how to configure the chip to support backplane/sfp modes? Thanks in advance.
Mike_Intel
Hello cathyz64,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Thank you.
Michael L.
cathyz64
Okay, thanks. Can you link me to the new thread?
CarlosAM_INTEL
Hello, @cathyz64:
You should refer to the information stated in sections 3.7.1.3, 3.7.2.1, and 3.7.4.2, on pages 113, 120, and 125 of the Intel® 82599 10 GbE Controller Datasheet document # 331520 that may help you. You can find it when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/331520
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided website. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
cathyz64
Right, we are already aware of the datasheet and those sections you mentioned. What we are really most interested in is the way to program the EEPROM, if there is an associated tool or firmware image to do so? As I stated, we are planning to use this chipset on a new product we are making and would like to pre-load the EEPROM with the settings we intend to use. Some direction in how this is done would be extremely helpful. Thanks.
CarlosAM_INTEL
Hello, @cathyz64:
Thanks for your reply.
You need to use an image that better fits your needs. You may find it in the Intel® 82599 10 Gigabit Ethernet Controller EEPROM Images document # 425136 when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/425136
@CarlosAM_INTEL.
cathyz64
I attempted to get a RDC sign in and was not successful. Is there another way I can reach this information? Or someone I could reach out to concerning a RDC account?
CarlosAM_INTEL
Hello, @cathyz64:
You should address your last questions following the last suggestion stated on this thread.
@CarlosAM_INTEL.
