Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
Compatibility of PCIe 2.0 device with I210-IT
NanjundaM
I'm using I210-IT in my design, Its a PCIe v2.1 device. But I want to interface it with PCIe switch 89HPES4T4G2ZCALGI and PCIe Clock buffer 9DB803DGILFT both are PCIe 2.0 devices.
So will this interfacing between PCIe 2,0 and PCIe 2.1 devices will work ?
Is I210-IT is compatible with PCIe v2.0 ?
Is I210-IT is compatible with PCIe switch and clock buffer mentioned above ?
Please help me ASAP.
Thanks & Regards,
Nanjunda M
PMorg1
Hi Nanjunda,
The speed of PCIe 2.1 is the same as PCIe 2.0 and also the signals looks the same. We are also using the I210-IT together with the PCIe clock buffer 9DB433 and this works fine. The 9DB803 should also work.
Patrick
CarlosAM_INTEL
Hello Nanju,
Thank you for contacting the Intel Embedded Community.
The information that may help you is stated in section 1.4.2, on page 13 of the http://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/i210-ethernet-controller-spec-update.pdf Intel® Ethernet Controller I210 Specification Update.
Please review as a reference the information stated at the http://pcisig.com/developers/integrators-list?keys=&order=field_integrator_revision&sort=asc Integrators List | PCI-SIG.
Please let us know if the provided information is useful to you.
Carlos_A.
PMorg1
Hi Nanjunda,
Patrick
