Estamos utilizando el I210 junto con una placa CPU con interface standard QSEVEN
Utilizamos un puerto PCI para conectarlo al I210.
El sistema operativo que utilizamos es CentOS pero no nos detecta el puerto Ethernet y creemos que podría ser debido a no disponer de la memoria flash de datos.
Es necesaria la meoria flash para el fucnionamiento del controlador?
Adjunto el esquema eléctrico
Hello, @JRubi10:
We suggest you verify that your are following the recommendations stated in the answer to the question 2.9 on page 6 of the Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document # 335346. This document can be found at:
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf
Thanks for your answer!
Where can we download the documents 513655 & 348742 and the tools: EEUPDATE and LANConf
Jose
Hello, @JRubi10:
Thanks for your reply.
The Intel(R) Ethernet Controller I210 and I211-AT: Production NVM Images document # 513655 and Intel(R) Network Connections Tools 24.0 PV LAN Software Tools document # 348742, which has the EEupdate, can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/513655.htm
http://www.intel.com/cd/edesign/library/asmo-na/eng/348742.htm
The RDC Account Support form is the channel to process your account update request. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
Hi;
We have tried to install the eeupdate tools but when we execute the install script application for LINUX32 we can see the following message.
unable to find driver file (iqvlinux.ko)
When could we find this file?
Our operating system is Centos 6.10 (kernel 2.6.32)
BR
Jose Luis
Hello, @JRubi10:
Thanks for your update.
Could you please let us know if you have consulted this situation in the following channel mentioned as a reference?
https://bugs.centos.org/view_all_bug_page.php
We are waiting for your reply.
Sorry for the delay in my reply.
We have redesigned our PCB and we have tried to program the flash included with i210 Ethernet controller, but it is not workng.
At the end we have used the DOS tools where we do not need drivers installed on CentOS but we have found other problem.
please review the doc attached and send to me your comments.
Jose
Hello, @JRubi10:
Thanks for your replies.
Could you please let us know the sources that you have used to based the redesign process?
Could you please confirm that your redesign has been reviewed by Intel?
We are waiting for your reply to these questions.
