Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
EEPROM Access Tool (V 0.7.9) I211 Flash in UBUNTU18.04 for Tegra (ARM64, r32.4.2, Jetson Xavier NX)
tomlin
Hi
There have been issues published before, and the recent chip issue switched to I210:
https://community.intel.com/t5/Embedded-Connectivity/EEPROM-Access-Tool-V-0-7-9-I211-Flash-in-UBUNTU...
now, nVIDIA Jetson Xivier NX + Eepromaccesstool 0.7.9 Dump error message "Check command open to write error)the dumped OTP file is empty 0.
Change to use another NANO processor, it shows that the programming is completed, but it still cannot be used after the power is turned off and restarted. The second programming will show that the same data has been programmed.
We think that the problem is the same as before, because of the number of times of burning, it cannot be burned again. We also tried to update flashtool ver0.8.0, but the result was the same but failed.
Could you please provide another i210 FW that has filled in the burning value?
Mike_Intel
Hello tomlin,
For us to further check the issue, please provide the following details.
  1. Are you designing a board/system with embedded network controller?
  2. Why do you need this information?
  3. Please provide further details on your design.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
tomlin
Hi Mike
A : base on nvidia design kit
https://developer.nvidia.com/embedded/jetson-nano-developer-kit
& Products we support
https://www.gigaipc.com/en/index.php?action=products2&cid=2&tid=31
A : 07-16-2020 We are here to solve the problem, the message is linked below. Now because of intel i211 LAN production problem change to use i210.
https://0rz.tw/fUDmY
A : Change only LAN IC.
Mike_Intel
Hello tomlin,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Please wait for their reply within 1 to 2 business days.
Thank you.
Michael L.
tomlin
hi Mike
 Is there any progress?
CarlosAM_INTEL
Hello, @tomlin:
Thanks for your update.
The transfer mentioned by @Mike_Intel is to the Intel Embedded Community.
Due to this fact, please follow the suggestion provided in our communication of January 12th.
@CarlosAM_INTEL
tomlin
Hi @CarlosAM_INTEL
 a. The same question was previously asked in this Embedded-Connectivity forum and received help:
https://community.intel.com/t5/Embedded-Connectivity/EEPROM-Access-Tool-V-0-7-9-I211-Flash-in-UBUNTU18-04-for-Tegra/m-p/1201110?profile. language=zh-TW
 b.IPS profile has been updated.
  On January 12th, the response was wait for their reply within 1 to 2 business days, there is no change or response at present, so I asked again if there is any progress.
CarlosAM_INTEL
Hello, @tomlin:
Thanks for your reply.
Please let us clarify the situation.
You still have a simple account but a premier account is needed to receive the proper support.
Please update your account as we suggested in our communication of the past January 12th.
@CarlosAM_INTEL.
tomlin
Hi @CarlosAM_INTEL
 how to know the premier account or simple? Only the application for the Premier account received from the developer zone has been approved.
CarlosAM_INTEL
Hello, @tomlin:
We sent an email to the address associated with this account with information that may help you and explain why your last reply has been edited.
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @tomlin:
You need to update your profile to the premier option to help you. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/developer/premier-registration.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the one provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
tomlin
