Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
918 Discussions
Errors while running Ethernet Port Configuration Tool on ESXi 8.0 U2
justanengineer
Hello. I'm attempting to run the EPCT on ESXi 8.x. I've downloaded 1.40.5.5 and followed the instructions to install using the following command:
esxcli software vib install -d <path/package_file>.zip
Further instructions for running / accessing the tool are not specifically given for ESXi.
My second attempt followed a post on this forum. I tried uploading the tool to my ESXi datastore and running the standalone application (as in 'sh ./epctn64e') This fails with syntax errors, and I've downloaded previous versions to see if I am hitting some sort of bug. I have attached a screenshot of these failures.
How do instantiate / access the tool after following the ESXi installation instructions in the README?
Thanks all.
IntelSupport
Community Manager
Hello justanengineer,
Since the inquiries is related to Programming or Embedded Products. Thus, we will move the thread to the Embedded Connectivity Community forum.
Hayat
Intel Customer Support
CarlosAM_INTEL
Hello, @justanengineer:
You have confirmed that this forum is a duplicate of the one stated on the following website:
https://community.intel.com/t5/Embedded-Connectivity/Re-Posted-Errors-while-running-Ethernet-Port-Configuration-Tool/m-p/1566126#M5095
You need to keep one open to give you the information that may help you.
@CarlosAM_INTEL.
