Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
941 Discussions
Ethernet Controller I211, How to handle unused pin
kzk6700
My design will use "I211" to convert PCI Express to Ethernet (100BASE-TX).
The following pins are unused and are open. Is this correct?
Should I connect to something?
・PE_WAKE_N(16)
・MDI_PLUS[2](53), MDI_MINUS[2](52), MDI_PLUS[3](50), MDI_MINUS[3](49)
・RSVD43(43), RSVD44(44)
・SDP0(63), SDP1(61), SDP2(62), SDP3(60)
・NC (22)
AlfredoS_Intel
Hi Kzk6700,
Thank you for posting in our Intel® Ethernet Communities Page.
Since your issue is regarding an embedded Intel Ethernet Controller , we need to route this thread to the correct group so you will be better assisted by the proper team.
Please wait for their reply within 1 to 2 business days.
Alfred S
Intel® Customer Support
CarlosAM_INTEL
Hello, @kzk6700:
You should review the schematic tab of the Intel Ethernet Controller I211-AT [Pearsonville] Layout Review Checklist document # 495297; and in sections 11.7 and 11.10, on pages 496 and 500 of the Intel® Ethernet Controller I211 Datasheet document # 333017, where you may find information that may answer your previous message. You can find these documents when you are logged into your Resource and Design Center (RDC) privileged account on the following websites:
https://cdrdv2.intel.com/v1/dl/getContent/495297
https://cdrdv2.intel.com/v1/dl/getContent/333017
You should fill out the form stated on the following website when you have problems with the provided websites or want to update your RDC account:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
