Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
915 Discussions
Ethernet failure when using the i210 Controller at +71C
CDest1
Hey,
We are seeing Ethernet with the i210 Controllers IT when testing at +71 C.
We would like to have someone look over our design and verify that our design meets the standard.
Are there test results or specifications for testing at high temperatures?
CarlosAM_INTEL
​Hello, @CDest1​ :
In order to be on the same page, could you please clarify if the affected units has been manufactured by you or a third-party company? In case that the affected units have been designed by you, could you please inform us the sources that you have used to develop it? By the way, could you please let us know how many units have been manufactured and how many are affected by this situation? If it is a third-party design, could you please give us all the information related to it?
Also, could you please provide pictures of the top side markings of the affected Ethernet controllers?
Waiting for the information that should answer these questions.
@Mæcenas_INTEL​.
CDest1
i210_location.pngThanks for your reply. Here are my answers below in bold:
Could you please clarify if the affected units has been manufactured by you or a third-party company?
The units were designed by us but are manufactured by a third party, Ducommun Incorporated and BEI Precision Systems & Space Company, Inc
We used this guide: I210-AT_I211-AT 1G-BASE-T REFERENCE DESIGN
https://www.intel.com/content/www/us/en/embedded/products/networking/i210-at-i211-at-1g-base-t-reference-design-schematic.html
We have probably assembled 50 or more and half of those units have been affected.
The design was done by ViaSat Inc. See the attachment for the schematic. (Note: the PDF only contains the pages that pertain to the i210 controllers.)
See attachment picture.
CarlosAM_INTEL
​Hello, @CDest1​ :
Thanks for your update.
Based on your previous communication and the provided pictures, could you please remove the Thermal Interface Material (TIM)
over each of the Ethernet Controllers and provide pictures of their top side markings?
By the way, could you please remove the TIM of each of the devices that have it , apply it again, install the thermal solution and verify if the problem persists?
The guidelines to remove and apply the TIM can be found at the following website:
https://www.intel.com/content/www/us/en/support/articles/000005576/processors.html
@Mæcenas_INTEL​.
CDest1
Hi Carlos,
My manager corrected on my previous reply,.
We have a total of 2000 units that have been made and in the past we have seen 1 out of three units failing at hot temperature.
I am inserting the picture of an i210 below
CarlosAM_INTEL
​Hello, @CDest1​:
However, could you please give us the information that should answer the second question of our previous communication as soon as you have it?
Waiting for your update.
@Mæcenas_INTEL​.
CDest1
Hi Carlos,
Our tests from last night showed that the failure still persisted after removing and reapplying the TIM.
Is it possible to set a conference call?
CarlosAM_INTEL
​Hello, @CDest1​ :
In order to help you, we have sent a message.
@Mæcenas_INTEL​.
CDest1
Carlos,
We have already confirmed that the chip is not getting too hot by:
  1. Using temperature sensors close to the chip
  2. Placing thermocouples on top of the chips' cases
We wanted to know some more info about the 25 MHz reference clock.
Here are the parts we are using for the Oscillator: SiT9120_LVDS_125MHZ and Frequency divider: AD9508BCPZ
PS, here is my email: cedric.destin@viasat.com
CDest1
Please find the datasheet for the crystal attached in this post.
CarlosAM_INTEL
​Hello, @CDest1​ :
In order to help you, we have contacted via email.
We hope that the provided suggestion may help you.
@Mæcenas_INTEL​.
