Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
How I can write my option rom to the i210 flash
伟何2
If I build the option rom for my i210(like ipxe),how I can write it to the I210 rom?
The BootUtil only can write the Intel option rom,how to write the third-part option rom?
Thank you very much.
Best Regards
Houssay Ho
CarlosAM_INTEL
Hello, hh:
Please review the answer to the question 2.19, on page 8 of the https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions (FAQs) document # 335346.
By the way, the Intel Network Connections 20.7 PV, Intel Pre-boot BIOS Image Utility BootUtil LAN Software Tools document # 387754 and Intel Network Connections [iSCSI boot BIOS firmware utility] LAN Software Tools document # 388381 can be found at:https://cdrd.intel.com/v1/dl/getContent/387754?wapkw=387754 4
https://cdrd.intel.com/v1/dl/getContent/387754 https://cdrd.intel.com/v1/dl/getContent/387754
https://cdrd.intel.com/v1/dl/getContent/388381 https://cdrd.intel.com/v1/dl/getContent/388381
These documents are accessible to you using the Resource & Design Center (RDC) privileged account.
In case that you want an RDC account, please request it by filling out the https://www-ssl.intel.com/content/www/us/en/forms/design/contact-support.html Resource & Design Center Account Support form.
We hope that this information may help you.
Carlos_A.
伟何2
Thank you for your respond.
I see the BootUtil only use *.flb file for update the option rom.
How I can build the *.flb file for my own option rom(*.bin file)?
The BootUtil can't use my own *.bin file.
Best Regards
Houssay Ho
CarlosAM_INTEL
Hello, hh :
Thanks for your update.
We suggest you address this request by filling out the https://plan.seek.intel.com/us_en_embedded_registration-form-contactsaleswebform_html Contact Sales form.
Carlos_A.
KK18
Good afternoon.
We designed a PCIe LAN card using i210 with an external Flash memory.
My questions are :
1) Can we develop "our own" option ROM code and store it in the Flash.  After PC power-on, during BIOS POST(PowerOnSelfTest), copy the option ROM code to system RAM and execute the code?
2) If we also need the original Intel option ROM code, can the 2 kinds of ROM code exist together in the same Flash?
     And what is the 2 ROM codes' executing prioirty?
3) And, how to write "our own" option ROM code (*.bin instead of *.flb) into the external Flash?
Thanks so much!
KK
CarlosAM_INTEL
Hello, @KK18:
You should review the information stated as answers to questions 2.14, 2.15,  and 2.16; on page 8 of the document stated on the following website:
https://cdrdv2.intel.com/v1/dl/getContent/334026
@CarlosAM_INTEL.
KK18
Hi Carlos_A,
Thank for your kindly reply.
I found the document you showed me but it seems only talking about many option ROM images provided by Intel.
My questions are :
1)    Can we develop "OUR OWN" option ROM image and store it in the Flash.  After PC power-on, during BIOS POST(PowerOnSelfTest), "OUR OWN" option ROM image could be copied to system RAM and executed ?
2)    If we also need the original Intel option ROM image, can the 2 kinds of ROM images exist together in the same Flash?
       And what is the 2 ROM images' executing prioirty?
Thanks!
KK
