Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
909 Discussions
How to eanble the L2A3341A1C-BH-DB MCTP support function
chen1
Can you please help to tell us how to eanble the L2A3341A1C-BH-DB MCTP MCTP mode?
Because our BMC team tried to get UUID can found MCTP support is disabled.
UUID response dump:
Enable channel 5 and sending UDID command to slave 0x61
[16845 : 16849 CRITICAL][I2CHelper.c:1208]MCTP: find a 5th device which address is 0x14
dump UDID: 0x11 0x40 0x9 0x80 0x86 0x15 0x1f 0x0 0x4 0x0 0x0 0x0 0x0 0xc9 0x0 0x0 0x0 0x29
                      (MSB)        (LSB)
The interface byte is 0x0004. Bit[5] = 0 = MCTP mode not supported. (Reference i350 datasheet section 10.5.5.4).
CarlosAM_INTEL
Hello, @chen1:
You can find the information that may help you in section 10.7, on pages 875 through 885 of the Intel® Ethernet Controller I350: Datasheet document # 333171.  It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/333171.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
