Our company has developed an embedded board using the Intel WG210-AT. I would like to get access to the utilities for programming the i210 NVM. When I attempt to use any of the links to those tools posted in the forums or elsewhere, I get an "access denied" message.
How do I request access to those utilities?
I am having some problems with the Intel web site and a large portion also shows up as either Greek or Russian language. My language preference is set to English.
Do the programming utilities run on ARM 64-bit Linux? We are using a Raspberry Pi Compute Module 4 running the Raspberry Pi OS 6 4-bit Linux. That is a derivative of Debian Linux compiled for the ARM v8 64-bit architecture on an arm A72 CPU. Can I obtain the necessary sources to compile the utilities on ARM 64-bit Linux?
Thanks for any help. I use the Intel developer site infrequently and am a bit confused about how to request access to resources and report issues with the web site.
Hi ErikWlfn,
Thank you for reaching Intel Community.
To ensure you receive the most specialized assistance, we have a dedicated forum that addresses these specific concerns.
Therefore, I will be moving this discussion to the respective team.
This will allow our knowledgeable community and experts to provide you with timely and accurate solutions.
Fikri O.
Hello @ErikWlfn,
You will need a Premier account in order to get access to these documents, also, being ARM what you are using, you can try with the EEPROM Access Tool [EAT], from document #572162.
To apply for a Premier account, you can check the following article:
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
