Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
922 토론
I am looking for a step file for X550-BT2.
RDeBa
초급자
3,649 조회수
0 포인트
12 응답
Mike_Intel
중재자
3,357 조회수
Hello RDeBa,
For me to further understand and assist you. Can you confirm if you are designing a system with this NIC?
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
0 포인트
RDeBa
초급자
3,357 조회수
Michael, I have an embedded design the uses the ELX550BT2 S LL2G Ethernet Controller. Not the NIC. I am requesting a 3D model (step file) for the ELX550BT2 S LL2G. Regards, Rene Rene DeBacker Hardware Engineering E: rdebacker@futurex.com<mailto:rdebacker@futurex.com> O: +1 (830) 980-9782 x1377 Enterprise encryption & key management solutions for securing the world’s most sensitive data.
0 포인트
Mike_Intel
중재자
3,357 조회수
Hello RDeBa,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
You may also try to post your inquiry here:
https://www.intel.com/content/www/us/en/design/resource-design-center.html
Michael L.
0 포인트
CarlosAM_INTEL
중재자
3,357 조회수
Hello, @RDeBa​:
Could you please let us know the propose to request this file?
We are waiting for your clarification.
@Mæcenas_INTEL​.
0 포인트
RDeBa
초급자
3,357 조회수
We are building a board that utilizes an X550-BT2 Ethernet controller. Previous version had an X540. We add step files for all components to the PCB for mechanical visualization in our chassis, and to understand what areas of the board require special cooling. We prefer that the manufacturers provide the files – especially for complex devices with dies that require cooling. I can create a monolithic block based on max dimensions in the datasheet but it is not as effective. Regards, Rene Rene DeBacker Hardware Engineering E: rdebacker@futurex.com<mailto:rdebacker@futurex.com> O: +1 (830) 980-9782 x1377 Enterprise encryption & key management solutions for securing the world’s most sensitive data.
0 포인트
CarlosAM_INTEL
중재자
3,357 조회수
Hello, @RDeBa​:
Thanks for your reply.
In order to help you we will contact you via email.
@Mæcenas_INTEL​.
0 포인트
RDeBa
초급자
3,357 조회수
Are there any updates on this step file request for the X550-BT2 Ethernet controller? Regards, Rene Rene DeBacker Hardware Engineering E: rdebacker@futurex.com<mailto:rdebacker@futurex.com> O: +1 (830) 980-9782 x1377 Enterprise encryption & key management solutions for securing the world’s most sensitive data.
0 포인트
CarlosAM_INTEL
중재자
3,357 조회수
Hello, @RDeBa​:
Could you please tell us if you have received our email sent to you the past 10/24/2019?
We are waiting for your confirmation.
@Mæcenas_INTEL​.
0 포인트
RDeBa
초급자
3,357 조회수
Yes I did. I was waiting for you to contact me via email. Regards, Rene Rene DeBacker Hardware Engineering E: rdebacker@futurex.com<mailto:rdebacker@futurex.com> O: +1 (830) 980-9782 x1377 Enterprise encryption & key management solutions for securing the world’s most sensitive data.
0 포인트
CarlosAM_INTEL
중재자
3,358 조회수
Hello, @RDeBa​:
Based on your confirmation, could you please tell us if you understand the suggestions stated in the cited email or not?
We are waiting for your reply.
@Mæcenas_INTEL​.
0 포인트
RDeBa
초급자
3,358 조회수
Here are the contents of the 10/24 email [cid:image001.png@01D594A2.9BD7C680] It is my understanding that Intel will contact me via email regarding the step file. I don’t see any suggestions. Regards, Rene Rene DeBacker Hardware Engineering E: rdebacker@futurex.com<mailto:rdebacker@futurex.com> O: +1 (830) 980-9782 x1377 Enterprise encryption & key management solutions for securing the world’s most sensitive data.
0 포인트
CarlosAM_INTEL
중재자
3,358 조회수
Hello, @RDeBa​:
Thanks for your update.
Unfortunately the image that you have attached is not visible. We are going to send again the email with the procedure that you should follow.
@Mæcenas_INTEL​.
0 포인트
응답
