Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
916 Discussions
I210 Operation in Flash-less mode
FFrey1
I'm trying to setup a system with two I210 controllers. The 2nd one operates in Flash-less mode
and I have problems to get it working.
I have successfully programmed the INVM using the eeupdate64e tool with:
eeupdate64e /nic=2 /invmupdate /file=I210_Invm_Copper_NoAPM_v0.6.txt
It now reports:
Using: Intel (R) PRO Network Connections SDK v2.25.20
EEUPDATE v5.25.20.03
Copyright (C) 1995 - 2015 Intel Corporation
Intel (R) Confidential and not for general distribution.
Driverless Mode
Warning: No Adapter Selected
NIC Bus Dev Fun Vendor-Device Branding string
1 1 00 00 8086-1533 Intel(R) I210 Gigabit Network Connection
2 3 00 00 8086-157B Intel(R) I210 Gigabit Network Connection
The 2nd NIC is the one without flash.
However, when I try to program the MAC address, it fails:
eeupdate64e /nic=2 /mac=001395160935
2: Updating Mac Address to 001395160935...Failed!
Further more when I load the driver "igb" in linux, it reports an
invalid checksum on the 2nd NIC:
Intel(R) Gigabit Ethernet Network Driver - version 5.3.2
Copyright (c) 2007-2015 Intel Corporation.
igb 0000:01:00.0: irq 76 for MSI/MSI-X
igb 0000:01:00.0: irq 77 for MSI/MSI-X
igb 0000:01:00.0: added PHC on eth0
igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
igb 0000:01:00.0: eth0: (PCIe:2.5GT/s:Width x1)
igb 0000:01:00.0 eth0: MAC: 00:13:95:16:09:34
igb 0000:01:00.0: eth0: PBA No: 000300-000
igb 0000:01:00.0: LRO is disabled
igb 0000:01:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
igb 0000:03:00.0: irq 78 for MSI/MSI-X
igb 0000:03:00.0: irq 79 for MSI/MSI-X
igb 0000:03:00.0: The NVM Checksum Is Not Valid
igb: probe of 0000:03:00.0 failed with error -5
Basically I have two questions now:
1. Why does the MAC address programming fail?
2. Why does the driver complain about the checksum? As far as I know there isn't
a checksum in the internal memory.
Felix
CarlosAM_INTEL
Hello Mephisto,
Thank you for contacting the Intel Embedded Community.
The information that may help you is stated at the following websites as a reference:
http://lxr.free-electrons.com/source/drivers/net/ethernet/intel/igb/e1000_i210.c Linux/drivers/net/ethernet/intel/igb/e1000_i210.c - Linux Cross Reference - Free Electrons
http://lxr.free-electrons.com/source/drivers/net/ethernet/intel/igb/igb_main.c Linux/drivers/net/ethernet/intel/igb/igb_main.c - Linux Cross Reference - Free Electrons
The I210 can be used without an external flash memory with very limited features. For example, no management interface or external PHY control via MDIO or I2C is available without flash memory. You can confirm this information in the answer to the question 2.9, on page 8 of the http://Intel® Ethernet Controller I210/I211 Frequently Asked Questions Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions (FAQs)
Please let us know if this information is useful to you.
Carlos_A.
FFrey1
Hello Carlos
You're pointing me to the kernel 4.2 sources. Unfortunately I'm bound to kernel 3.14.
However, I also tested with igb driver version 5.3.2, which is even never than kernel 4.2 and it
issues the same error as igb driver version 5.0.5-k which is part of kernel 3.14.
Further more, even if the driver is buggy it doesn't explain why the MAC address programming fails.
Any other ideas?
Felix
WSchr1
Hi Mephisto
i had maybe the same problem with the eepromARMTool, i got also the Error 5 thing.
My I210 has a FLASH device an because i could not program it i tryed to use th INVM.
I changed the "tool" only to see that there is no flash device was pesent.
I could setup a MAC and fill the INVM but i got that Error 5.
I think the driver (igb.ko) is not looking for the vendor and device-id (8086-157B), i think he's asking the I210 if a FLASH device is present and try to check his ckecksumm.
My resolution was to remove the FLASH device... The I210 dosend found a FLASH and i get rid of Error 5.
Maybe your eeupdate64e does any same thing than the igb.ko.
My concusion: don't atach a FLASH if you want to use the INVM.
Wolfgang
Felix,
Sorry to reopen an old post but I am having the exact same problems. Did you ever get the issue resolved?
Thanks,Chris
