Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
I350: Device ID 1521 is sometimes 151F / lanconfw64e: c86a2017 - "IOCTL to driver failed"
GSmol
Dear Intel Community,
in our industrial measurement device, we have designed an embedded Ethernet card based on 3 chips of I350 (NH1350AM2) dual 1G Ethernet interfaces each card.
We have at last 6 I350 chips in each measurement device, which provide 12 Ethernet interfaces for fast video data transfer to the embedded PC-Module.
Some times, at last every 20 or 50 power cycle, the i350 losses its configuration data, and its Device-ID changes from 1521 to 151F.
The Device-ID change affects each time to both Ethernet Interfaces at the same i350 chip.
We have an EEPROM as configuration storage device connected to the i350.
https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-318185/pastedImage_8.png
https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-318184/pastedImage_7.png https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-318186/pastedImage_9.png
The entire PCI structure in the system looks then like this:
https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-318188/pastedImage_11.png
Once, the I350 has changed its ID to 151F, I could read out the EEPROM Raw-Data by the lanconfw64e.exe, and it was look like in the next picture:
https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-318183/PegasusPC-SN1077_Win7x64Pro_lanconf64%28PCIBus6.0.1%29.png
After few reboots, the lanconfw64e shows the correct Device-ID on both Ethernet interfaces at the same i350 chip:
https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-317888/PegasusPC-SN1077_Win7x64Pro_lanconf64%28PCIBus6.0.0%29.png
During this try, I can see that the EEPROM is readable, and not corrupted.
My question is, if someone has already the same problem with Intel wired Ethernet chips, what could be the cause of this and how to avoid it ?
Additionally if the chips are configured correctly during the boot-up, I can not read the EEPROM data on every Dev-Id 1521 interfaces, getting the following error message from lanconfw64e:
https://communities.intel.com/servlet/JiveServlet/showImage/2-439252-318189/imageFile.png
So that is my second question ,what could be the cause of this error message, and how can I fix it ?
I would be very glad if someone could help me to loose this problems.
Best regards.
GregorS.
CarlosAM_INTEL
Hello, GregorS:
In order to better understand this situation, we would like to address the following questions:
Could you please tell us how many boards are failing and how many has been produced?
Could you confirm if your design has been implemented based on the information stated in the http://www.intel.com/content/dam/www/public/us/en/documents/reference-guides/ethernet-controller-i350-reference-design.pdf Intel® Ethernet Controller I350: Reference Design and http://www.intel.com/content/dam/www/public/us/en/documents/reference-guides/x550-bt2-x540-i350-bt2-reference-design.pdf X550-BT2/X540/I350-BT2: Reference Design?
Could you please let us know if the affected project has been reviewed by Intel?
Please let us all the information that may answer these questions to have a better idea of this problem.
Thanks in advance for your help.
Carlos_A.
