Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
I210IS PECLKx standard
SergejDziuba
Hello!
We are designing our own PCB and use i210IS chip.
So, we need to know what type of differential input clock does PECLKp/n signals use? LVDS? HCSL or another?
Thank you!
Looking forward your answer!
Sergej.
Zigfreid_Intel
Hello SergejDziuba,
Your query will be best answered by our Embedded Connectivity Support team. We will help you move this post to the designated team for further assistance.
Please feel free to contact us if you need assistance from Ethernet support team.
Zigfreid I.
Intel® Customer Support
CarlosAM_INTEL
Hello, @SergejDziuba:
You need to have a Resource and Design Center (RDC) privileged account to have access to the requested information.
The RDC Account Support form is the channel to process your account update process by filling out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
Adolfo_S_Intel
Can you confirm if this current post from you is related to this previous post: https://community.intel.com/t5/Embedded-Connectivity/I210IS-PECLKx-standard/td-p/1328121/jump-to/first-unread-message or if it is a different issue?
@Adolfo_S_Intel
SergejDziuba
Yes, it is.
So, where can get explanation for my question?
Thank you!
Adolfo_S_Intel
If you check the Intel I210 datasheet: https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/i210-cs-cl-ethernet-controller-datasheet.pdf?asset=14546
Section 9.6.2.6, you can read the following:
 The input clock for PCIe must be a differential input clock in frequency of 100 MHz. For full specifications please check the PCI Express* 2.0 Card Electro-Mechanical (CEM) Specification (refclk specifications for Gen 1 ).
So the answer to your question is on the PECLKp/n signals follow the PCI Express® Card Electromechanical Specification Revision 1.1 for the Refclk.
Now, you will have to confirm this on your side, but at least for Revision 2.0 of the CEM specification: https://www.cl.cam.ac.uk/~djm202/pdf/specifications/pcie/PCI_Express_CEM_r2.0.pdf  the Refclk is stated to be low voltage swing differential clocks.
If you need more details, as mentioned earlier, access to the Intel Resource and Design Center is recommended.
@Adolfo_S_Intel
