Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
930 Discussions
Intel X710-BM2: Which Firmware Image to choose for SFP & SFP+ compatibility (nvmupdate)
C_KE
Dear all,
as our SFP+-Port (10GbE) isn't compatible with SFP (1 GbE), I am looking for the right firmware image to provide compatibility.
Toolchain: Several years ago (FW Generation 6p01) I used eeupdate64e to programm the X710 Flash, but now it seems nvmupdate64e is the way to go. I downloaded the FW-Images 8p30 and updated my network driver (kernel module) i40e.
Up until now, I couldn't figure out which Image is suitable for both SFP+ (10 GbE) and SFP (1GbE).
Can you give me any advice to help me fix this?
Mike_Intel
Hello IPE_CKE,
Before we proceed, let me check. Are you designing a board or a system with embedded X710-BM2?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
C_KE
Hello Mr Michael L.,
the board carrying the X710-BM2 is already designed.
Up until now we used the Firmware image named "XL710_X710_6p01_SFI_Backplane_MCTP_CFGID7p0_Quad_800034AA.bin".
The 10GbE over SFP+ DAC/fibre worked as expected.
However, the problem comes with 1GbE SFP.
I can't build a link over normal SFP-Modules. I validated the modules using an Intel Ethernet X710DA2 SVR.
Thats the reason why I suspect the firmware image to be the root cause.
Christoph Keil
Mike_Intel
Hello IPE_CKE,
Thank you for the quick reply. So the board has been designed, however this is in the testing stage? Or this is a production system already?
Michael L.
C_KE
Hello Mr Michael L,
we are developing a new board based on the old one concering the ethernet controller.
Thats why we want to fix our SFP/SFP+ compatibility issue.
Best regards
Christoph K
CarlosAM_INTEL
Hello, @C_KE:
We want to address the following questions to better understand this situation:
Could you please confirm if you are using a document to ensure that the migration process would be correct?
Could you please let us know if the new implementation has been verified by Intel?
We are waiting for your reply to these questions.
@CarlosAM_INTEL.
C_KE
Hello CarlosAM_INTEL,
our schematics are based on Intels reference schematics of the X710 controller.
The X710 supports SFP+ perfectly but when it comes to SFP I am not able to achieve a link.
I just couldn`t figure out which nvm-image matches my requirements.
Best regards
IPE_CKE
CarlosAM_INTEL
Hello, @C_KE:
Thanks for your update.
We have sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @IPE_CKE:
Thanks for your reply.
We have sent another email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @IPE_CKE:
We have sent a new email to the address associated with this account with suggestions that may help you.
@CarlosAM_INTEL.
Mike_Intel
Hello IPE_CKE,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Thank you.
Michael L.
