Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
Ankündigungen
Internal Compiler Error
Kakos
Einsteiger
4.268Aufrufe
Hello, recently I am running switchml P4 code on Tofino programmable switch (the code can be found in GITHUB), currently I am using version 9.7.4 of sde, during the compilation process there is an internal compiler error, the log message only shows some WARNING and no other ERROR, and I also asked the question in the official P4 forum, but the reply said the problem would be different depending on the compiler version, and the specific problem might be the P4 code writing, but there is no specific book about the problem, so I would like to seek an answer, thank you very much!
4 Antworten
CarlosAM_INTEL
4.235Aufrufe
Hello, @Kakos:
We received your consultation.
However, we want to address the following question:
Could you please confirm that this forum is a duplicate of the one stated in the following website created by you?
https://community.intel.com/t5/Embedded-Connectivity/Internal-compiler-Error/m-p/1501152#M4529
We are waiting for your answer.
@CarlosAM_INTEL.
Kakos
Einsteiger
4.211Aufrufe
Yes,it is because of network fluctuations that I submitted it again.However,I couldn't find the delete botton, and I  apologize for that.If you have the authority to delete it, I would be extremely grateful.
CarlosAM_INTEL
4.174Aufrufe
Hello, @Kakos:
Thanks for your update, there is no problem.
We need to clarify that this forum is for Embedded products but you may try this link to ask any questions related to Tofino Switches:
https://plan.seek.intel.com/programmable-ethernet-switch
@CarlosAM_INTEL.
duansima
Einsteiger
2.445Aufrufe
hello, have you figured it out?
Antworten
