Hello, recently I am running switchml P4 code on Tofino programmable switch (the code can be found in GITHUB), currently I am using version 9.7.4 of sde, during the compilation process there is an internal compiler error, the log message only shows some WARNING and no other ERROR, and I also asked the question in the official P4 forum, but the reply said the problem would be different depending on the compiler version, and the specific problem might be the P4 code writing, but there is no specific book about the problem, so I would like to seek an answer, thank you very much!
連結已複製
Hello, @Kakos:
We received your consultation.
However, we want to address the following question:
Could you please confirm that this forum is a duplicate of the one stated in the following website created by you?
https://community.intel.com/t5/Embedded-Connectivity/Internal-compiler-Error/m-p/1501152#M4529
We are waiting for your answer.
Yes,it is because of network fluctuations that I submitted it again.However,I couldn't find the delete botton, and I apologize for that.If you have the authority to delete it, I would be extremely grateful.
Hello, @Kakos:
Thanks for your update, there is no problem.
We need to clarify that this forum is for Embedded products but you may try this link to ask any questions related to Tofino Switches:
https://plan.seek.intel.com/programmable-ethernet-switch
