Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
899 Discussions
Internal construction of WGI210AT S LJXQ
Ioan1
Can you please advise the internal construction of WGI210AT S LJXQ?
(1) monolithic integrated circuits in which the circuit elements (diodes, transistors, resistors, capacitors, inductances, etc.) are created in the mass (essentially) and on the surface of a semiconductor or compound semiconductor material (for example, doped silicon, gallium arsenide, silicon germanium, indium phosphide) and are inseparably associated;
(2) hybrid integrated circuits in which passive elements (resistors, capacitors, inductances, etc.), obtained by thin- or thick-film technology, and active elements (diodes, transistors, monolithic integrated circuits, etc.), obtained by semiconductor technology, are combined to all intents and purposes indivisibly, by interconnections or interconnecting cables, on a single insulating substrate (glass, ceramic, etc.). These circuits may also include discrete components;
(3) multichip integrated circuits consisting of two or more interconnected monolithic integrated circuits combined to all intents and purposes indivisibly, whether or not on one or more insulating substrates, with or without lead frames, but with no other active or passive circuit elements;
(4) multi-component integrated circuits (MCOs): a combination of one or more monolithic, hybrid, or multi-chip integrated circuits with at least one of the following components : silicon-based sensors, actuators, oscillators, resonators or combinations thereof, or components performing the functions of articles classifiable under heading 8532, 8533, 8541, or inductors classifiable under heading 8504, formed to all intents and purposes indivisibly into a single body like an integrated circuit, as a component of a kind used for assembly onto a printed circuit board (PCB) or other carrier, through the connecting of pins, leads, balls, lands, bumps, or pads.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
We received your request, we would like to address the following questions to understand it:
Could you please let us know the reasons to request this information? Is it related to determining the right EU HTS number?
Where did you buy the mentioned part number?
We are waiting for your reply to these questions.
@CarlosAM_INTEL.
Ioan1
Yes, the request is related to determine the right EU HTS
We purchased this item from mouser.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
Thanks for your clarification.
The Product Specification portal has the EU HTS information for any Intel devices.  You can find it on the following website:
https://ark.intel.com/content/www/us/en/ark.html
You need to type the part number of the Intel product in the search specification bar and then click on the magnifier button of the cited portal, as is stated in the following image, specifically in the sections highlighted with the numbers 1 and 2:
You should click on the Ordering and Compliance option in the new window, as is shown in the section highlighted with the number 3 of the attached image.
Next, the Trade Compliance information section, specifically in the last row, is stated the EU HTS information, as you may notice in the attached image as well.
The EU HTS number 8542310001 is the information for the Intel® Ethernet Controller I210-AT (part number WGI210AT).  This information is stated on the following website:
https://ark.intel.com/content/www/us/en/ark/products/64400/intel-ethernet-controller-i210at.html
We hope that this explanation may help you to find the EU HTS information in the future.
@CarlosAM_INTEL.
Ioan1
Thank you for the tutorial.
Can you please also advise which of the four description fit the best for the item?
We need this information and is not listed in the datasheet.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
Thanks for your reply.
We sent an email to the address related to this account with information that may help you with your last request.
@CarlosAM_INTEL.
