Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
Is it possible to output I210 test pattern with Tegra X2?(1000BASE-T)
YUchi1
We want to output test pattern(1000BASE-T) of I210 with Tegra X2.
Is there tool for test pattern of arm 64 bit?
If there is tool for test pattern of arm 64 bit, Could you send me of test tool?
Or is there a register in I 210 to output the test pattern?
If there is a register in I210, Could you tell me how to change that register and register.
We are developing in the following environment.
・CPU/GPU​   :Tegra X2(ARM Cortex-A57)
・OS​ :Linux ubuntu
・​Carrier Board :We developed the Board
・​NIC :I210IT×2
If there is a lack of information, please let us know.
CarlosAM_INTEL
​Hello, @YUchi1​:
Thanks for your updates.
We will contact you via email.
@Mæcenas_INTEL​.
YUchi1
Hello @Mæcenas_INTEL​
We accessed the following site, but the error could not be accessed.
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
The contents of the error are as follows.
You don't have Access to IPS.
Please contact the FAE to get access.
If you are an Employee and want Customer Role, Please raise request in AGS
Do you know the cause?
Best,regard.
CarlosAM_INTEL
​Hello, @YUchi1​:
Thanks for your update.
We will contact you via email to help you.
@Mæcenas_INTEL​.
YUchi1
Thank you for your reply.
When will we receive an email?
Will it arrive by March 27 in Japan time?​
Best,regard.​
CarlosAM_INTEL
​Hello, @YUchi1​:
Thanks for your reply.
We have contacted you via email.
@Mæcenas_INTEL​.
