Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
919 Discussions
WGI210IT-SLJXS - Ethernet not able to ping connected device
Dharanihebbar
We are using WGI210IT-SLJXS/SLJXT IC in our design, while testing we are not able to ping the connected device. But MAC IC is displayed.
All drivers are installed.
Any software coding is required? Kindly do need full.
Attached circuit diagram for reference.
Fariz_Intel
Hi Dharanihebbar,
It seems that your question is related to design using WGI210IT Ethernet Controllers. We might have a forum for those specific issues and we are moving it to Embedded Connectivity so it can get answered accordingly.
Fariz_Intel
Diego_INTEL
Hello @Dharanihebbar,
You can check the complete driver pack:
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Also, you can check the following:
Document #333016 - Intel® Ethernet Controller I210: Datasheet
https://www.intel.com/content/www/us/en/content-details/333016/intel-ethernet-controller-i210-datasheet.html?DocID=333016
Document #334026 - Intel® Ethernet Controller I210/I211: FAQ
https://www.intel.com/content/www/us/en/content-details/334026/intel-ethernet-controller-i210-i211-faq.html
Document #513305 - Intel® Ethernet Controller I210 [Springville] Dual Design Guide (Premier account required)
@Diego_INTEL
Dharanihebbar
Hello Diego,
  • In document FAQ in section 2.9 it is mentioned that in "I210 without external flash memory no management interface or autonomous external PHY control via MDIO or I2C is available without flash memory".
  • We are powering ON WGI210IT-SLJXS/SLJXT for the first time in our design, so do we need to do any external memory flashing. If yes, please guide us to do external memory flash.
  • Attaching circuit diagram, kindly review.
  • We are communicating with zingtron Kontron EV distributor, attached mail communication.
Thanks and regards,
Dharani
