Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
X550 AT2 Thermal data
JB100
I was wondering if there are any more detailed thermal specifications on the X550 AT2 17x17mm chip. The datasheet isn't very thorough on this, and I would like to do a thermal model for this unit running in a warmer environment.
Datasheet only supplies this: Theta j-a and Psi j-t
Mike_Intel
Hello JB100,
Before we proceed and for us to further check this inquiry. Let me just ask if you are designing a board or a system with embedded X550-AT2 card? How would you implement this and please tell us why do you need the thermal data?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
JB100
Hi Michael,
We are designing a board where we use this chip, and need to ensure that we manage the thermals for this IC. The datasheet shows data that we need to keep this device cool with both ports running at 10G.
We are looking to design or implement a heat sink solution, different from the one in the datasheet, but require more data than the datasheet has.
Jason
Mike_Intel
Hello JB100,
Base on your inquiry, we have specific forum for these issues, we need to route this thread to the correct group so you will be better assisted by the proper team.
Please wait for their reply within 1 to 2 business days.
Thank you.
Michael L.
CarlosAM_INTEL
Hello, @JB100
We sent an email to the email address related to your account with information that may help you.
@CarlosAM_INTEL.
JB100
