Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
eepromARMtool
MPatt3
Where do I find the eepromARMtool code? I am working on an ARM based design that uses an i210. I would like to program the NVM via this tool so that I can get the driver to load.
Matt
PPast3
Hi Adolfo,
I'm look for the same tool (eepromARMtool) i need to program my new hardware with i210 into SerDes Mode could you email the tool also.
Pawel
MPatt3
Do you mean program it with a 3rd party programmer off board? With a blank part the eeprom arm tool crashes before we can program anything.
ldong6
Hi AdolfoS, I am working on an ARM based design that uses an i210. Where do I find the eepromARMtool code? thanks.
email: mailto:[email protected] [email protected]
SConn1
Hi Aldolfo,
We are also looking to program the I210 on an ARM platform. We are looking to program the INVM. Do you have a tool for that?
Natalie_Z_Intel
Hi, Seamus! We'll get back with you on this question. We see that you have /message/12657?et=watches.email.thread# 12657 another post which we'll address in this thread, too. LynnZ.
Hello Seamus,
I've sent you an e-mail with the requested tool. Please confirm that you have received it.
If you have any other question please let us know.
Jimmy.
PPast3
Hi Adolfo,
Pawel
Sofian
Hi @CarlosAM_INTEL
I'm looking for the same tool for ARM CPU based (eepromARMtool) and I need to test the tools on i211, could you send me email for the tool also ?
Sofian
CarlosAM_INTEL
Hello, @Sofian:
The Intel I210, I211, and X550 EEPROM Access Tool (EAT) document # 572162 is the updated version of the requested tool. It can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/572162.htm
The RDC Account Support form is the channel to process your account update request or any inconvenience related to the provided website. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
@CarlosAM_INTEL.
Sofian
Hi @CarlosAM_INTEL
Thanks for your reply.
I got problem when I try to access the link that you gave me.
so I open the case #04828040.
Sofian
CarlosAM_INTEL
Hello, @Sofian:
Thanks for your answer.
Actually, we suggest following our last suggestion to solve the mentioned inconvenience.
@CarlosAM_INTEL.
ccbow
Hello, We are working with the I210 with an external eeprom and would like to get a copy of the eepromARMtool to get started with getting the chip up and running.
Can you please send me a copy.
Diego_INTEL
Hello @ccbow,
You can check document #572162 - EEPROM Access Tool [EAT] in RDC.
You will need a Premier account in order to get access to the document, you may check this article:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
@Diego_INTEL
WSchr1
Hi Adolfo,
I'm aols looking to get the eepromARMtool, could you send me a copy?
Thanks in advance,
Wolfgang
Gabriel_T_Intel
Hello Wolfgang,
Welcome to the Intel Embedded Community.
We are going to contact you by email.
Gabriel Thomas
STuba
Hello Adolfo,
We are also looking to program the EEPROM of the I210 and 82574L chips on an i.MX6 ARM platform.
Can you please send me the source code of your tool?
Thank you and Best Regards
Stefano
ACest
we need to program I210 flash from a ARM procesor, could you send to me the eepromARMtool and HEX to put in flash?
Alberto
CarlosAM_INTEL
Hello Alberto,
Thank you for contacting the Intel Embedded Community.
We will contact you via email to help you.
Carlos_A.
PHall1
Hello, We are working with the I210 with an external eeprom and would like to get a copy of the eepromARMtool to get started with getting the chip up and running. Can you please send me a copy.
CarlosAM_INTEL
Hello Peter_Hall,
Carlos_A.
AFade
Hello AdolfoS
Could you also send ARM tool to me?
CarlosAM_INTEL
Hello AlexandrFadeev,
Carlos_A.
