Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
eepromARMtool
MPatt3
Where do I find the eepromARMtool code? I am working on an ARM based design that uses an i210. I would like to program the NVM via this tool so that I can get the driver to load.
Matt
PPast3
Hi Adolfo,
I'm look for the same tool (eepromARMtool) i need to program my new hardware with i210 into SerDes Mode could you email the tool also.
Pawel
OChri
we would also need to have the eepromarmtool. Could you please provide a download link for us?
Olaf
CarlosAM_INTEL
Hello Olaf,
Thank you for contacting the Intel Embedded Community.
We are working to give you an update as soon as possible.
Thanks in advance for your patience and understanding.
Carlos_A.
CarlosAM_INTEL
Hello Olaf,
We will contact you via email to help you.
Carlos_A.
hlun
CarlosAM_INTEL
Hello helun,
This tool is available when you have an Embedded Design Center (EDC) Privileged account. In order to request a Privileged EDC account, go to http://www.intel.com/content/www/us/en/forms/design/registration-privileged.html http://www.intel.com/content/www/us/en/forms/design/registration-privileged.html and filling out the form. The application can be found at:
https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html
In order to help you with this process, we suggest you use a business email address to evade any inconvenience. Please avoid the free email provider's address (such the provided by Hotmail, Gmail, yahoo, or others).
We hope that this information may help you.
Carlos_A.
Can you send the eepromARMtool to me?My board is based on NVIDIA JETSON TX2 and intel 82574.
CarlosAM_INTEL
Hello, pww:
It is important to let you know that an EDC account should be required to have access to this tool. To learn more about the benefits of an EDC Privileged account go to http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html. Then click on "APPLY NOW" found under the heading, "Apply for extras with privileged access to the Intel EDC¹".
We hope that this information is useful to you.
Carlos_A.
lqin3
We have designed our own board with 82599 and NVIDIA JETSON TX2,
I've tried the link above, but no "APPLY NOW" found, just "Submit" some infomation and my question.
So, could you send the eepromARMtool to me?
CarlosAM_INTEL
Hello, qqdelphis:
We suggest you use a business email address to evade any inconvenience. Please avoid the free email provider's address (such the provided by Hotmail, Gmail, yahoo, or others).
Carlos_A.
VSchl1
Hi there
In order to program an I210 flash from a ARM processor, we too require the eepromARMtool. Could someone provide this piece of software?
Best Regards
Valentin
Gabriel_T_Intel
Hello Valentin.
Welcome to Intel® Embedded Community.
I sent you the eepromARMTool to your e-mail.
If you have any other question or request please let us know.
Please confirm if you have received this file.
Best Regards.
Gabriel Thomas.
VSchl1
Hi
Thank you for your quick reply.
Unfortunately we are not yet able to write a hex image into the flash memory attached to our I210.
We are able to see our devices (with lspci as well as with the eepromARMtool):
$ sudo ./eepromARMtool
Intel(R) Eeprom ARM Tool ARM OTP Programming Tool
Provided under the terms of a CNDA. Do Not Distribute.
Copyright(C) 2013 by Intel(R) Corporation
NIC BUS DEV FUN Silicon Memory Type Present
1 3 0 0 I210 INVM+FLASH
2 4 0 0 I210 INVM+FLASH
When trying to write a hex image, we get the following output, but no positive confirmation of the process:
$ sudo ./eepromARMtool -write -NIC=1 -f=Dev_Start_I210_Copper_NOMNG_16Mb_A2_3.25_0.03.hex
Intel(R) Eeprom ARM Tool NVM/OTP Programming Tool
Copyright(C) 2013-2014 by Intel(R) Corporation
Version 0.6.7
Flash wordsize reg val: 5 register 82a00
After this process, the I210 devices are still listed as unflashed with lspci and a reboot does not change anything. The command for dumping the Flash ($ sudo ./eepromARMtool -dump -NIC=1 yields the same data as in the hex file, however there seems to be nothing transmitted to the flash memory.) After a reboot the dump is empty again.
$ lspci
03:00.0 Ethernet controller: Intel Corporation Device 1531 (rev 03)
04:00.0 Ethernet controller: Intel Corporation Device 1531 (rev 03)
Could you provide us with any pointers as to what we are doing wrong?
Thanks, best regards
Valentin
Gabriel_T_Intel
Hello Valentin .
1)When you enter the dump command sudo ./eepromARMtool -dump -NIC=1, does it generates a file as I210NIC1.OTP ?
2) Can you try a different file to program the device, different than: Dev_Start_I210_Copper_NOMNG_16Mb_A2_3.25_0.03.hex ?
3)Verify the Flash File format, which should be a table of a 8 columns and X rows of 16 bit words, presented in hexadecimal, similar than the following one:
Best Regards.
Gabriel Thomas.
VSchl1
thanks for your reply. We have tried your suggestions and the results are below:
Yes, we can generate a dump file but it is different depending on when we generate it.
After a reboot the dump appears to be mostly empty:
$ more I210NIC.otp
0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 E781 4C22 0AA0 AA86
Then after applying the write command ( $ sudo ./eepromARMtool -write -NIC=1 -f=Dev_Start_I210_Copper_NOMNG_16Mb_A2_3.25_0.03.hex ) the dump seems to represent the hex file that we try to write to the I210:
$ more I210NIC.otp
A000 00C9 0000 0520 FFFF 3025 FFFF FFFF
0003 0000 402F 0000 FFFF 1533 8086 3367
8100 003D 67FF 00C1 E024 0040 2400 FFFF
303D 7000 5A0E 3400 0084 0000 3200 0706
200C 0584 0000 FFFF 0200 803D 0010 0098
1C68 003C 8000 0701 00F8 0097 1000 05F8
0100 4000 1332 4003 FFFF 4000 FFFF 00F9
FFFF FFFF FFFF FFFF 0094 0430 FFFF 479E
8170 003D 05CD 8000 FFFF FFFF FFFF FFFF
FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0000 0080 FFFF FFFF FFFF FFFF FFFF FFFF
But after a reboot, a dump of the device is empty again.
We tried the example Hex-file for MCTP and 16Mb, as well as NOMNG and 8Mb with the same results. Our attached memory is actually 32 Mb, but according to the documentation a too large memory should be of no concern.
The file format is correct.
We also had a look at the source code and figured out that the function "PollFlashUpdateDoneI210" never returns success. We measured the NVM-Port of the I210 to the flash memory with an oscilloscope and don't see any signals during the writing process.
So it appears to us that the data is sent to the I210 and stored in the Shadow RAM, but never written into the external flash memory.
Could there be any issue blocking the I210 from actually writing the data into the flash memory?
Valentin
VSchl1
Hi
We have narrowed down the problem somewhat. When trying to write a hex file with a configuration to the external flash with the eepromarmtool ($ sudo ./eepromARMtool -write -NIC=1 -f=Dev_Start_I210_Copper_NOMNG_16Mb_A2_3.25_0.03.hex) the following occurs:
It seems that the process of updating the flash (writing the contents of the shadow RAM to the external Flash memory) does not succeed.
The function "UpdateFlashI210" attempts to poll for the FLUDONE bit in the EEC register of the I210. This bit should be set by the chip to indicate "Flash Update Complete" or in this case probably ready for the first Flash update. Because this bit is never set, the process of writing to the Flash does not begin.
Trying to manually override waiting for the FLUDONE bit and instead directly attempt to write to the flash by setting the FLUPD bit in the EEC register did not end successfully.
Does anyone have an idea, why the UpdateFlash fails?
Valentin
Gabriel_T_Intel
Hello Valentin.
Have you verified if the Flash Memory you are using is included in the list of the validated Flash parts, from https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/i210-ethernet-controller-datasheet.html Intel® Ethernet Controller I210 https://www-ssl.intel.com/content/www/us/en/embedded/products/networking/i210-ethernet-controller-datasheet.html Datasheet document,
section 11.8.1 Flash.
Gabriel.
VSchl1
Hi Gabriel
We are using a SST25VF032B Flash memory which is listed in the I210-Datasheet as "Compatible by design but not tested."
It seems that the memory gets detected, since we can read the following registers in the I210 (among others):
- EEPROM-Mode Control Register (EEC): 0x482a00 FLASH_DETECTED bit = 1b (the flash memory is not busy and returned a manufacturer ID)
- Flash Access Register (FLA): LOCKED bit = 0b (the flash memory is not in the secure mode)
- Flash Op-code Register (FLASHOP): 0xb7a75c7 (is correct)
- Flash Mode Register (FLASHMODE): 0x42 SST_MODE = 1b, FLASH_SPEED = 00b (both appear to be correct)
We are still observing the same behaviour that our hex file is read into the Shadow RAM but not written into the Flash memory, as described above.
Valentin
Gabriel_T_Intel
Hello Valentin.
Could you tell us please what flavor of I210 are you using?
I210-AT (Commercial Cooper).
I210-IS (Industrial Temperature Cooper).
I210-IT (Industrial Temperature Fiber).
Gabriel.
VSchl1
Hello Gabriel
We are using the I210-AT version.
Valentin
VSchl1
Hi everyone
Unfortunately we are still experiencing the same problem with the I210 not allowing to copy the configuration data in the internal shadow RAM (from the .HEX file) into the flash memory.
Does anyone have any pointers as to what we might be doing wrong?
Valentin
Gabriel_T_Intel
Hello Valentin.
I am sorry for the delay. We still working in your issue.
We will contact you as soon as possible.
Best Regards
Gabriel.
