Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
how to force link, speed, duplex linkup and disable auto negotiation with serdes unidirectional link (receive only)
DVais
disconnected transmit lines of serdes and enabling only receive lines while in 1000BASE-KX and did not received any packet while trying to force link, speed, duplex linkup and disable auto negotiation, registers dump attached.
CarlosAM_INTEL
Hello, @DVais​:
In order to better understand this situation, we want to address the following questions:
Could you please clarify if this situation happens on your design or a third- party design?
In case that it is a third-party device, could you please inform the name of the manufacturer, its model, the part number, and where its documentation is stated?
On the other hand, could you please let us know how many units of the project related to this circumstance have been manufactured? How many are affected? Could you please give the failure rate? Also, could you please list the sources that you have used to design it and if it has been verified by Intel?
We are waiting for your reply to these questions.
@Mæcenas_INTEL​.
