Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discusiones
i210 LED configuration confusion
tegunulgener
Novato
3.033 Vistas
hi,
My issue here is, LED0 default value is 0110 and the default hex value for LED control is "0x00E00 00078406". What i need is change it to 0111 (0x00E00 00078407).
I can change it with LANConf through registers but i cannot save it to eeprom. 873 pages of datasheet is either too confusing or not clear.
Could you please help me to understand how to change the raw eeprom value?
I attached the eeprom dump
thanks in advance @Diego_INTEL
tegun_U
0 kudos
4 Respuestas
Sazirah
Empleados
2.987 Vistas
Hi tegunulgener,
Thank you for contacting Intel Community Support.
This is related to your enquiry for Intel Ethernet Controller i210.
For this request, we have Intel Embedded team who is dedicated expert team for this products that will assist you on this. We will move this forum thread to their team, please give some time for them to get back to you.
Sazzy_Intel
tegunulgener
Novato
2.951 Vistas
Hi, yes it is our design, it is embedded. It is exactly the same board as the previous case.
ps: We are still waiting to hear from Intel for the previous issue yet another problem to be solved.
tegunulgener
Novato
2.843 Vistas
you can close this topic. we found the solution. thanks.
Diego_INTEL
Moderador
2.708 Vistas
Hello @tegunulgener,
My apologies for the late reply, I'm glad that you could find a solution.
@Diego_INTEL
Responder
