Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
931 Discussions
i210/i211 eeupdate on DOS - This program cannot be run in DOS mode
blackcapacitor
I am trying to program the iNVM on an I211AT Ethernet controller from a DOS bootable USB using the eeupdate utility, but am running into a few issues.  For one, I am not exactly sure which of the many eeupdate tools in document 348742 download (Quartzville Tools) to use - there are folders for all supported operating systems, expect for DOS.
When I do try to execute the WIN32 EEUPDATEW32.exe application from DOS, it returns: "This program cannot be run in DOS mode".  Does anyone know what the issue is?  Am I using the wrong eeupdate application?  Does the version of DOS I am using just not allow this application to be executed?
I would greatly appreciate any help on this issue.
AlfredoS_Intel
Hi Blackcapacitor,
Thank you for posting in our Intel® Ethernet Communities Page.
Since your issue is regarding an embedded Intel Ethernet Adapter that you are trying to update, we need to route this thread to the correct group so you will be better assisted by the proper team.
Please wait for their reply within 1 to 2 business days.
Alfred S
Intel® Customer Support
AlfredoS_Intel
Hi Blackcapacitor,
Alfred S
CarlosAM_INTEL
Hello, @blackcapacitor:
We suggest verifying that you fulfill the requirements stated in the Installing the tool on DOS section of the Intel(R) EEUpdate Release Notes document included in the DOCS file of the Intel® Network Connections Tools 25.2 PV LAN Software Tools document # 348742. It can be found when you are logged into your Resource & Design Center (RDC) privileged account on the following website:
http://www.intel.com/cd/edesign/library/asmo-na/eng/348742.htm
The RDC Account Support form is the channel to process your account update request or report any inconveniences with the provided site. It can be found at:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
blackcapacitor
Yes, I have read the "eeupdate.txt" file in the DOCS folder of the 348742 download, but that does not answer my first question - can you tell me which of the "EEUPDATE" applications located in the TOOLS folder that I need to use on DOS?  Is it the "EEUPDATEW32.exe" one located in the "Win32" folder?  Or is it a different one?
I don't see a folder for "DOS" so I at least need to verify that I am trying to use the correct application.
Chase
CarlosAM_INTEL
Thanks for your reply.
Based on your replies, we want to address the following questions to have a complete view of this situation:
Could you please let us know what the DOS that you are using (name of the developer, version, and other details)?
Could you please provide the procedure that you are following to run the DOS related to this situation?
We are waiting for your answer to these questions.
@CarlosAM_INTEL.
blackcapacitor
Yes, I can definitely provide that information.  I am using FreeDOS (version 7.10), which I am running from a bootable USB drive (1GB thumbdrive).  I imaged the USB with the Rufus tool (v3.11).
With the bootable USB created, I then copy the "EEUPDATEW32.exe" application from the "Win32" folder in TOOLS from document 348742, along with the I211 production image text file, onto the root of the bootable DOS USB.
I then boot my i7-7820EQ COM Express computer from the bootable DOS USB and then try to run the "EEUPDATEW32.exe" application.  DOS returns "Cannot run program from DOS mode".
So the question is, am I using the correct EEUPDATE application?  Or am I using a wrong/incompatible version of DOS?
CarlosAM_INTEL
Based on your last communication, could you please try to reproduce this situation using a DOS version developed by Microsoft and let us know the results?
We are waiting for your reply.
@CarlosAM_INTEL.
blackcapacitor
Hi @CarlosAM_INTEL
Can you please at least let me know if I am using the correct eeupdate application to run on DOS?  Is the "EEUPDATEW32.exe" application from the Win32 the right one to use with DOS?  I still have not gotten an answer to my first question.
CarlosAM_INTEL
In case that the cited .exe file is included in the latest version of the Intel(R) Network Connections Tools 25.2 (at this moment) PV LAN Software Tools document # 348742. Also, you can found it when you are logged into your RDC privileged account as well, on the following website:
It is correct for the cited use.
@CarlosAM_INTEL.
blackcapacitor
Hi @CarlosAM_INTEL
That still doesn't answer the question - can you tell me which of the folders within the "TOOLS" folder (i.e. Win32, Win64, EFI_x64, Linux64, etc.) do I need to use with DOS?  There obviously is no "DOS" folder in the Network Connections Tools 25.2 download at this moment, so which one do I need to use for DOS?
Also that link you sent me does not work.
CarlosAM_INTEL
Attached you may find the DOS location.
By the way, the procedure step by step on how to run it is the following:
C:\Users\User\OneDrive -  Corporation\Desktop\Server\Ethernet Training\Lanconf\TOOLS\Winx64\OEM_Mfg>install /y
Welcome to the Tools driver installation program.
After installation of the driver (iqvw64e.sys), the tool can be invoked.
Checking to see if iqvw64e.sys exists on system
No existing iqvw64e.sys file exists
Copying iqvw64e.sys file to C:\windows\system32\drivers
        1 file(s) copied.
Installing INF file
Microsoft PnP Utility
Processing inf :            iqvw64e.inf
Driver package added successfully.
Published name :            oem153.inf
Total attempted:              1
Number successfully imported: 1
Installation done!  You can now invoke the tool.  To exit,
Press any key to continue . . .
C:\Users\User\OneDrive - Corporation\Desktop\Server\Ethernet Training\Lanconf\TOOLS\Winx64\OEM_Mfg>dir
Volume in drive C is OSDisk
Volume Serial Number is EC58-DC3C
Directory of C:\Users\User\OneDrive -  Corporation\Desktop\Server\Ethernet Training\Lanconf\TOOLS\Winx64\OEM_Mfg
09/28/2020  12:44 PM    <DIR>          .
09/28/2020  12:44 PM    <DIR>          ..
04/19/2019  03:13 AM         4,263,424 celow64e.exe
04/26/2019  05:55 AM         4,374,040 EEUPDATEW64e.exe
10/12/2018  06:21 AM             3,303 install.bat
10/12/2018  06:21 AM            10,209 iqvw64e.cat
10/12/2018  06:21 AM             2,386 iqvw64e.inf
10/12/2018  06:21 AM            58,520 iqvw64e.sys
04/18/2019  05:47 AM         5,280,200 nvmupdatew64e.exe
               7 File(s)     13,992,082 bytes
               2 Dir(s)  350,339,190,784 bytes free
C:\Users\User\OneDrive -  Corporation\Desktop\Server\Ethernet Training\Lanconf\TOOLS\Winx64\OEM_Mfg>EEUPDATEW64e.exe
Using: Intel (R) PRO Network Connections SDK v2.33.15
EEUPDATE v5.33.15.02
Copyright (C) 1995 - 2019 Intel Corporation
Intel (R) Confidential and not for general distribution.
Warning: No Adapter Selected
NIC Bus Dev Fun Vendor-Device  Branding string
  1   0  31  06   8086-15BD    Intel(R) Ethernet Connection (6) I219-LM
C:\Users\arabbani\OneDrive - Intel Corporation\Desktop\Server\Ethernet Training\Lanconf\TOOLS\Winx64\OEM_Mfg>
@CarlosAM_INTEL.
blackcapacitor
I think I found the solution through a different thread - as it turns out, there is a different download for the Network Connection Tools document (348743) for the DOS specific software.  So none of the tools available in the document 348742 would work on DOS.
Intel® Network Connections Tools 24.1 PV DOS only LAN Software Tools  https://cdrdv2.intel.com/v1/dl/getContent/348743
CarlosAM_INTEL
Thanks for your reply, also to share your experience.
@CarlosAM_INTEL.
