Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
951 Discussions
i210 programming flash by using u-boot or VxWorks
t-suzuki
I am working on an ARM based custom CPU board that uses an i210.
I think I need to program the iNVM and/or the external FLASH somehow to some initial configuration, However, I do not understand how to do it.
- Are there any tool can be executed from U-Boot or VxWorks 7?
- Where can I find the sample configuration file(s)?
- How can I get them?
Can anyone help me?
Jaime_Lizarme
Hi Tatsuya,
The information that may help you is described in the following FAQ questions 2.14, 2.15, 2.16
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.... Intel(R) Ethernet Controller I210/I211 Frequently Asked Questions [FAQs] document # 335346.
As to your last questions about tool being able to execute in U-Boot or VxWorks 7; I am afraid that the EEupdate is only available on EFI, Windows and Linux; no source codes available.
We hope that this information is useful.
Jaime L.
t-suzuki
Hello Jaime,
Thank you for your reply.
If I understood your answer correctly, I have to find a way somehow to program the iNVM and the external FLASH.
Is it possible to run the EEupdate from the Embedded Linux (such as Ubuntu)?
Anyway, I need to know the format of the data to be programmed into the iNVM/FLASH.
However, I cannot access the 513655 images archive mentioned in the "ethernet-controller-i210-i211-faq".
How can I access to such information?
