Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
956 Discussions
i40e MAC filter hash state failed
SantoshSingh
I am seeing an issue where the VLAN tagged packets are being dropped by the NIC.
Using "ethtool -S" I can see that the "port.rx_unicast " counters are incrementing but its not being forwarded to the right interface.
I posted this question under "Ethernet Products" support category and was asked to post it in this category, below is the detail.
https://community.intel.com/t5/Ethernet-Products/i40e-MAC-filter-hash-state-failed/m-p/1508175/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExLSVFBWUlFNk5WTlZDfDE1MDgxNzV8U1VCU0NSSVBUSU9OU3xoSw#M33955
I am seeing a bunch of following error message from driver -
[4749759.121075] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.127199] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.127411] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.134685] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.134897] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.135108] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.135318] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.135527] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.136592] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749759.136799] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749760.069988] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749760.070208] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749760.070426] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
[4749760.070639] i40e 0000:4b:00.2: Error I40E_AQ_RC_ENOSPC adding RX filters on PF, promiscuous mode forced on
sonic@sonic-ucs-m6-3:~$
It appears that there is no more space in the MAC Filter HT.
Can someone please confirm this?
Also, is there any way to disable this "MAC Filter" in NIC and make it accept ALL the VLAN tagged packets?
Thanks & Regards,
Santosh
CarlosAM_INTEL
Hello, @SantoshSingh:
We received your consultations, but we want to address the following questions to understand them:
Could you please confirm if the device related to this situation has been designed by you or a third-party developer? In case it is a third-party device, please let us know the name of the manufacturer and the part number of the device.
Could you please confirm if this situation is related to an Intel Ethernet Controller, NIC card, or adding card? Please mention the name of the manufacturer and part number.
We are waiting for your clarification.
@CarlosAM_INTEL.
SantoshSingh
The machine is Cisco UCS Server.
Below are the details -
Linux Version -
5.15.0-78-generic #85-Ubuntu SMP Fri Jul 7 15:25:09 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Below is the NIC detail
b1:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
b1:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
b1:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
b1:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
~$ ethtool -i ens108f0
driver: i40e
version: 5.15.0-78-generic
firmware-version: 5.05 0x80002b50 0.385.8
expansion-rom-version:
bus-info: 0000:b1:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
#:/home/tester# ethtool -k ens108f0
Features for ens108f0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: on
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: off
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-tunnel-remcsum-segmentation: off [fixed]
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: off [fixed]
tx-udp-segmentation: on
tx-gso-list: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off
hw-tc-offload: on
esp-hw-offload: off [fixed]
esp-tx-csum-hw-offload: off [fixed]
rx-udp_tunnel-port-offload: on
tls-hw-tx-offload: off [fixed]
tls-hw-rx-offload: off [fixed]
rx-gro-hw: off [fixed]
tls-hw-record: off [fixed]
rx-gro-list: off
macsec-hw-offload: off [fixed]
rx-udp-gro-forwarding: off
hsr-tag-ins-offload: off [fixed]
hsr-tag-rm-offload: off [fixed]
hsr-fwd-offload: off [fixed]
hsr-dup-offload: off [fixed]
CarlosAM_INTEL
Thanks for your reply.
Based on your last reply, you need to address your consultations of the cited third-party device as a reference through the channels listed on the following websites:
https://community.cisco.com/t5/cisco-developed-ucs-integrations/ct-p/4354j-cisco-dev-ucs-integ
https://supportassistant.cisco.com/
https://www.cisco.com/c/en/us/support/index.html
@CarlosAM_INTEL.
