Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
912 Discussions
iNVM programmed i210 speed reducing to 10Mbps
Shafi
Hi
We have implemented i210 in our custom carrier card without external flash.  We have successfully flashed iNVM with the images and we see ethernet port created. But when we connect to host laptop, the speed is showing as 10Mbps.  Sometimes the ethernet port created will continuously shows link up for 1000Mbps and it goes down.
Do we need to program any internal registers of i210 to make it 100Mbps or 1000Mbps ?
Shafi.
CarlosAM_INTEL
Hello,  @Shafi:
We want to address the following questions to understand this situation:
Could you please let us know the INVM file that you used? And, where do you find it?
Where do you buy the Intel® Ethernet Controller I210  related to this situation? What are the documents used to implement your design?
We are waiting for your answer.
@CarlosAM_INTEL.
Shafi
Hi CarlosAM_INTEL,
Appreciate your quick response.
We have implemented i210-IT as per the reference schematic.
https://www.intel.nl/content/dam/www/public/us/en/documents/schematic/i210-at-82574-nic-reference-dual-design-schematic.pdf
We are using Elkhart Lake x6000 and  PCIeC interface from CPU to i210.  Hardware design implementation is without external flash.  We are using Yocto Linux, kernel version is 5.10.
We have downloaded the EEPROM tool for Linux from below weblink.
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html?wapkw=i210%20nvm%20update
iNVM production image are downloaded from below link.
https://cdrdv2.intel.com/v1/dl/getContent/513655
I210_Invm_Copper_NoAPM_v0.6.txt is used to flash the iNVM.
 ./eeupdate64e /NIC=1 /INVMUPDATE /FILE=I210_Invm_Copper_NoAPM_v0.6.txt /MAC=1CFD0873D2EF
Our Hardware design supplier purchased  WGI210IT S LJXS from https://www.yic-electronics.com/pdf/WGI210IT.html.
Shafi.
CarlosAM_INTEL
Hello, @Shafi
Thanks for your reply.
The information stated in sections 3.7.1, 6.8.6.1 (FSD’s info), 3.7.8.5.4, and Table 3-30, on pages 88, 234, 120, 121, and 115 of the document stated in the following website may help you to solve the reported situation:
https://cdrdv2-public.intel.com/333016/333016%20-%20I210_Datasheet_v_3_7.pdf
@CarlosAM_INTEL.
Shafi
Thank you for reply.  I have gone through the sections as mentioned by you.
Is there any document which will help me in how to program the registers mentioned in the sections(sections 3.7.1, 6.8.6.1 (FSD’s info), 3.7.8.5.4, and Table 3-30, on pages 88, 234, 120, 121, and 115 ).  Presently only PCIe interface from SoC to i210 is available.
Shafi.
CarlosAM_INTEL
Hello,  @Shafi:
You need to update your profile to the premier option to help you. You should fill out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
You should use a business email address to evade any inconvenience. Please avoid the free email provider's address (such as the one provided by Hotmail, Gmail, Yahoo, or others).
@CarlosAM_INTEL.
