Embedded Connectivity
Intel network controllers, Firmware, and drivers support systems
923 Discussions
need Linux64 SVTools , in document #348742 file Linux64 is emptry.
liuliyuan
dear all,
My computer is ubuntu Linux64.
I just want set registerlike this:
and enter some test mode. but i don`t know what tools i can use,
becase in document # 348742 file Linux64 is emptry.
and EepromAccessTool can not help me...
I need some help.
thanks all
CarlosAM_INTEL
Hello, @liuliyuan:
We sent an email to the address related to this account with suggestions that may help you.
@CarlosAM_INTEL.
liuliyuan
hi,@CarlosAM_INTEL
thank you for your reply.
but I install the driver,and can`t run the lanconf64e. I think SVTools is not support Arm.
My requirement is actually very simple, I just want to open the test mode of I211 on PCIE, but I don`t known how to set the register with out tools.
Perhaps you can use tools such as Busybox devmem and devmem2 to directly write the value of an address to enable i211 to open the test mode, but after reading the manual, I don't quite understand how to set it.
so I need you help, Because if my company needs to use this chip a lot, we must pass the test mode test.
CarlosAM_INTEL
Hello, @liuliyuan:
Thanks for your reply.
@CarlosAM_INTEL.
bangbanghai
Hello, I have the same problem. Could you please send a suggestion to my email address?Thank you very much!     zhanghb@cdtyx.cn
CarlosAM_INTEL
Hello, @bangbanghai:
You need to have a Resource and Design Center (RDC) privileged account to provide you the information that may help you.
The RDC Account Support form is the channel to process your account update process by filling out the form stated on the following website:
https://www.intel.com/content/www/us/en/forms/support/my-intel-sign-on-support.html
@CarlosAM_INTEL.
