hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Embedded Intel Atom® Processors
Technological Conversations about Intel Atom® Hardware, Software, Firmware, Graphics
1209 Discussions
About Conga SA7 Intel® Atom® x6425E with Broadcom PEX8619 PCIe Switch Issue
burakagca
Hi Everyone,
I designed a box PC using Conga SA7 with Intel® Atom® x6425E processor SMARC 2.1 module. The PC has 10 port GbE output and expected to operate as a managable ethernet switch. As mentioned in the Conga SA7 datasheet a custom BIOS needed to convert 4x1 PCIe root complex to 1x4 PCIe root complex. Therefore I demanded the related BIOS binary file and flashed it to the ROM. However  PEX8619 PCIe switch(configured as x4x1x1x1x1x1x1x1x1x1x1x1x1) that I used to obtain 10 endpoint output for operating PCIe to GbE phy ICs LAN7430 is not working in Windows 10 pro (I couldn't see the PCI to PCI bridge or something like that in the device manager tree ).
If windows 10 can't see the PCIe switch in device manager then I also can't operate 10 port GbE outputs because the root complex of the CPU accesses the PCIe to GbE ICs via PCIe switch.
Is there anybody who has already used a PCIe switch and had an issue like this before?  Could anyone give an advise how to solve this problem?
PEX8619 datasheet: https://docs.broadcom.com/doc/PEX_8619-BA_Data_Book_v1.3_31Mar11.pdf
Conga SA7 manual:
https://www.congatec.com/fileadmin/user_upload/Documents/Manual/SA70.pdf
Thanks in advance,
CarlosAM_INTEL
Hello, @burakagca:
You need to address your consultation related to the cited third-party device as a reference using the form stated on the following website:
https://www.congatec.com/us/congatec-support/
@CarlosAM_INTEL.
