Atom E6xx CLK-DQS skew
cb Hello,
We are busy with the pcb layout for a Atom E6xx with 8 loads memory.
I am now confused about the length matching between the clock (CLK) and stobe (DQS) lines.
In the datasheet 433311_Rev3.0.pdf on page 36 is mentioned:
The total length of DQS of each byte group must be greater than or equal to CLK + 0.15 in., and must be less than or equal to CLK + 0.5 in.
If I then look at the guideline 325550.pdf (Intel® Atom™ processor E6xx Series – Memory Design Optimization for Small Form Factor), I see on page 23:
The total length of DQS of each byte group must be greater than or equal to CLK - 0.3 in., and must be less than or equal to CLK + 0.2 in.
What should I use for the length of the DQS line matching to the CLK?
Thanks!
FMcNu1
Valued Contributor I
Hello
I want to make you aware of a special place to go with questions like yours. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel® Atom™ and associated chipsets.
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Privileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
