1249 Discussions
Intel atom E6xx tunnel creek board with BIOS or without BIOS???????
Are there two varities of intel atom tunnel creek board E6xx???? with BIOS and without BIOS??
Also how to go to BIOS set up in intel atom tunnel creek E6xx boards. Which key we have to press in order to go to the BIOS? The one having in my lab is preloaded with fedora OS. I want to change the OS. I was not able to go to BIOS set up screen which will display which drive to boot first. Please help.
Also all atom boards have bootloader IC. If One removes the bootloader IC and attaches a USB drive, the atom processor would boot from the USB or it will fail??? Please help
FMcNu1
Valued Contributor I
Hello again.
If you obtained the development board from Intel, it appears there was only one configuration available.
If you have not already found these, here are some documents that might be helpful:
http://download.intel.com/design/intarch/manuals/324213.pdf# iid=3878 http://download.intel.com/design/intarch/manuals/324213.pdf# iid=3878
http://download.intel.com/embedded/processor/prez/Atom-301_Training.pdf http://download.intel.com/embedded/processor/prez/Atom-301_Training.pdf
I hope this helps
FMcNu1
Hello
I want to make you aware of a special place to go with questions like yours. The Intel® e-Help desk is staffed by Intel representatives who support select Intel embedded platforms including Intel® Atom™ and associated chipsets.
To access e-Help, you need to be a Privileged member of the Intel® Embedded Community.
If you are not already a Privileged member, you can request an upgrade to your community account here:
https://edc.intel.com/My-Account.aspx https://edc.intel.com/My-Account.aspx
In addition to access to e-Help, Privileged members may also access the confidential content within the Intel® Embedded Design Center, such as design documents, specifications, and training materials.
I hope this helps.
Felix
J. Felix McNulty
Community Moderator (Intel contractor)
FMcNu1
Hello again.
I hope this helps
ok thank you i will try the procedure in my lab tomorrow and reply. Thank you for guiding
Also can you tell me will atom processors have a boot menu , if so which key should i press to go to the boot menu of tunnel creek e6xx board??
FMcNu1
Hi:
In the user guide at the link I provided in previous post,
Please check out section 6.4.1 of this doc. It says press F2 or Delete during boot to enter the BIOS setup
Felix
