Bay Trail USB host issue
HTay
Hello and good day,
This issue cropped up when using the Micro-USB host on a Bay Trail Android engineering sample tablet; because there's only that single USB port on the tablet, I have to connect a USB drive & keyboard via USB hub in order to boot another OS (or the Android KitKat installer provided at 01.org).
I tried booting Fedora 20/21 (using Linux kernels v3.11, v3.15 and v3.16), but the system stops responding to my keyboard/mouse inputs shortly after the the graphical desktop (or text login prompt) is displayed. I can still see system activity happening, e.g. the clock updates the time, but the USB hub status led turns off, and re-plugging doesn't work.
This issue also happens when I try to use the keyboard and mouse on the preinstalled Android (kernel v3.10), they work okayl for a while but the USB hub typically goes out of action when Android wakes from sleep. Naturally I tried with different USB hubs and thumbdrives but the issue persists.
Could this be a kernel issue? More specifically, could this be an issue with the 64-bit kernel? Because I didn't notice this issue when I previously booted 32-bit Fedora on (slightly) older Bay Trail Windows tablets.
Please let me know if you guys have a different diagnosis and/or a solution to this issue.
Many thanks and best regards,
Hugh Tay
Casey_H_Intel
Hello Hugh,
The initial concern is that the hub(s) may not be compatible with the device. You'll need to confirm with both the hub and tablet manufacturer that these devices are compatible. Our advice is to seek support from the manufacturer of the tablet.
Casey H.
Casey_H_Intel
Hello Hugh,
I am running your scenario by engineers working on Bay Trail platforms. I will reply again when I have received information from them.
Casey H.
HTay
Hello Casey,
Thanks for helping to check about this, meanwhile I will also try to do more tests on my end to see if I can narrow down the problem further.
Best regards and cheers,
Hugh
Casey_H_Intel
Hello Hugh,
Casey H.
HTay
Hello Casey,
Many thanks for helping to investigate with this issue, we'll go with your suggestion. At least now we can be reasonably confident it's not a problem with Bay Trail architecture in general. =)
Hugh
HTay
Hi Casey,
I went to check with the OEM about this issue, and they said it's likely caused by, I quote, "Intel's watch-dog in charger driver is timeout (approximately 160s) so that turn off USB power".
Interestingly enough they suggested I check with your team regarding the official recommendation to address this issue, at least in the case of Android.
Any ideas?
Hugh
Casey_H_Intel
Hello Hugh,
I don't see in this thread that you have tested using Windows 7 or Windows 8.1. Have you tested either of those OSs to see if the same issue occurs?
Also, where are you pulling the drivers for the Android OS?
Casey H.
HTay
Good day Casey,
According to the OEM, they don't have any plans to build a Windows 7/8.1 port to their tablet right now, so unfortunately I'm not able to test this USB host issue with Windows. On the other hand, they seem positive about coming up with a fix in the USB driver after they talked to other teams also working on Bay Trail tablets.
As for Android drivers in general, apparently I'm supposed to get them from the Intel portal service at
https://businessportal.intel.com/irj/portal https://businessportal.intel.com/irj/portal
but I'm not able to access this service, what should I do?
Many thanks and cheers,
Hugh
Casey_H_Intel
Hello again Hugh,
The Android BSP you are working with comes from 01.org, correct? If so, you would need to contact them for support information.
However, there are http://www.intel.com/content/www/us/en/intelligent-systems/software/android-software-optimizations-atom-platforms.html?wapkw=android BSP's available from Intel ecosystem vendors. Please let us know if that site provides the correct BSP for your system.
Casey H.
HTay
Hello Casey,
Gosh! Sorry for replying so late... I had to go out of town and I didn't realize you had replied. Thanks so much for the BSP info, it's certainly helpful, and I will check with our vendor accordingly!
Hugh Tay
MShig3
FWIW here's Insyde's answer regarding my account request and BSP query (good they told it beforehand two weeks ago):
However, we only have binaries/files that work with the Intel Bayley Bay CRB development board. It will not work with anything else and we do not advise attempting to install this on anything besides this CRB.
