1249 Discussions
[Bay trail] Bay trail HDA can not output from HDMI
JLee169
Hi All
My platform is Bay trail -I E3845 D0, BIOS is coreboot + intel FSP3, test OS is WIN7.
Issue description:
on WIN7 device control manager have HDA, use HDMI interface Video have
output, but audio no, from reltek codedec alc886 connect to earphone have output.
I check code, I find FSP look like to write verbtable fail, so after fsp initial, I rewrite
verb table again its success, but HDA still no output.
below is I check result,
1. VGA ROM pass its leavage from AMI mp project.
2. verbtable pass, I rewrite.
3. HDA device is on pass.
4. i2s fail. device manager should be show correct monitor model name, but just show pnp monitor.
5. reltek codec earphone pass.
I want know
1. Intel have porting guide for HDA?
2. have other point I not yet to check?
thanks.
Best Regards
James
Gabriel_T_Intel
Hello James.
We are searching for a possible reason why the HDMI is not working properly.
In the meanwhile please review the http://www.intel.com/content/www/us/en/standards/high-definition-audio-specification.html High Definition Audio Specification document.
Please disable the reltek codedec acl886 and just try with the HDA in the HDMI to test.
Best Regards.
Gabriel Thomas
JLee169
Hi Gabriel,
Ok,thank you.
My PC today is crash, wait my fixed done, I will try to disable reltek,and report test result to you, thanks.
Best Regard
James
Hi James,
It looks as if the graphics driver is not installed since your HDMI monitor is not detected.
There is another audio driver that comes along with the graphic driver package which should get this setup working.
Here a link to get the driver package for both Windows 32bit & 64bit.
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23584 Intel® Embedded Media and Graphics Driver for Windows* 7 (build # 1064) v36.15.0 (32bit) and v37.15.0 (64bit)
Leon
JLee169
Hi Leon,
update your VGA driver test result is same, the audio also no output.
and driver on setup time have get the intel hda.thanks.
Best Regards
James
Hi James,
We would to hear more about your issue, have you managed to find a solution?
If not please let us know so we could find further solutions.
Have a nice day!
Leon
JLee169
Hi Leon,
No any solution for this issue, just pending ....
thanks
Best Regards
James
