1223 Discussions
Could you please specify which (if any) of the below descriptions are applicable for the part: PN: A
Ioan1
Could you please specify which (if any) of the below descriptions are applicable for the part: PN: ABB-050004337 MPN: CT80618005844AB 905806
(1) monolithic integrated circuits in which the circuit elements (diodes, transistors, resistors, capacitors, inductances, etc.) are created in the mass (essentially) and on the surface of a semiconductor or compound semiconductor material (for example, doped silicon, gallium arsenide, silicon germanium, indium phosphide) and are inseparably associated;
(2) hybrid integrated circuits in which passive elements (resistors, capacitors, inductances, etc.), obtained by thin- or thick-film technology, and active elements (diodes, transistors, monolithic integrated circuits, etc.), obtained by semiconductor technology, are combined to all intents and purposes indivisibly, by interconnections or interconnecting cables, on a single insulating substrate (glass, ceramic, etc.). These circuits may also include discrete components;
(3) multichip integrated circuits consisting of two or more interconnected monolithic integrated circuits combined to all intents and purposes indivisibly, whether or not on one or more insulating substrates, with or without lead frames, but with no other active or passive circuit elements;
(4) multi-component integrated circuits (MCOs): a combination of one or more monolithic, hybrid, or multi-chip integrated circuits with at least one of the following components : silicon-based sensors, actuators, oscillators, resonators or combinations thereof, or components performing the functions of articles classifiable under heading 8532, 8533, 8541, or inductors classifiable under heading 8504, formed to all intents and purposes indivisibly into a single body like an integrated circuit, as a component of a kind used for assembly onto a printed circuit board (PCB) or other carrier, through the connecting of pins, leads, balls, lands, bumps, or pads.
If it does not fit any description, please tell us the closest one and what is missing to fit properly.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
Thanks for contacting Intel Embedded Community.
We received your communication.
However, we want to address the following questions to better understand your request:
Could you please let us know the reasons to address your previous communications?
Where do you acquire the Intel Atom® Processor E620T processors mentioned in your previous message?
We are waiting for your answer.
@CarlosAM_INTEL.
Ioan1
This is a new project, I don't have this information right now. I need the confirmation of the construction for custom classfication code determination.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
Thanks for your reply.
You answered only our first question.
Could you please answer the rest of the questions stated in our previous message?
Best regards.
@CarlosAM_INTEL.
Ioan1
I don't have the information for the second question.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
Based on your reply, could you please find the requested information and let us know it?
Thanks in advance for your answer.
@CarlosAM_INTEL.
Ioan1
I've checked and our supplier is B&R Industrial Automation Gmbh. Please let us know if you can help with the construction of the item.
Ioan
CarlosAM_INTEL
Hello, @Ioan1:
We sent an email to the address associated with this account with information that may help you.
@CarlosAM_INTEL.
CarlosAM_INTEL
Hello, @Ioan1:
Thanks for your email.
We sent another email to the address associated with this account with HTS code information that may help you.
@CarlosAM_INTEL.
